Thread: How to remove "Upper Trim Panel" on the dash?
Results 1 to 8 of 8
Metal Links How to remove "Upper Trim... 05-17-2015, 06:32 PM
REDCRAPGP Re: How to remove "Upper Trim... 05-17-2015, 06:36 PM
Metal Links Re: How to remove "Upper Trim... 05-17-2015, 07:10 PM
Gratefuldiver Re: How to remove "Upper Trim... 09-24-2015, 01:52 PM
REDCRAPGP Re: How to remove "Upper Trim... 09-24-2015, 02:23 PM
Gratefuldiver Re: How to remove "Upper Trim... 09-24-2015, 02:25 PM
JohnRider Re: How to remove "Upper Trim... 09-09-2016, 03:13 PM
HighOctaneRacing Re: How to remove "Upper Trim... 09-09-2016, 11:04 PM
  1. #1 How to remove "Upper Trim Panel" on the dash?
    SE Level Member Metal Links's Avatar
    Dec 2013
    NJ
    I want to try and fix the cracks on the upper trim panel, where the defroster vent is located. I was able to lift it(It seems like the previous owner broke the clips) but there seems to be foam tape preventing me from removing it further. Should I just yank it to remove it? I wash planning to glue it back together than possibly vinyl wrapping it.
    I took some pics of what I am talking about:
    http://imgur.com/a/gB1zj
  2. #2 Re: How to remove "Upper Trim Panel" on the dash?
    Honestly it's probably very brittle.. Most crack. For $80 or so it's worth just getting a brand new one that will last you awhile.
    04 Comp G.
  3. #3 Re: How to remove "Upper Trim Panel" on the dash?
    Dec 2013
    NJ
    Yeah, it is super brittle...If I can't get it out in 2 or 3 pieces I will buy a new one.
    Would this be good for wrapping that panel? Never used vinyl wrap before.
    http://www.amazon.com/gp/product/B00...A38KC3G8X6TR19
    I figured the vinyl wrap would smooth out the defects and keep it in one piece.
  4. #4 Re: How to remove "Upper Trim Panel" on the dash?
    Jul 2015
    USA
    Bringing this one back with question for OP
    Did it just pop out like any other trim piece, no screws just clips?
  5. #5 Re: How to remove "Upper Trim Panel" on the dash?
    Yup just pops out like the rest of the trim panels. It's usually pretty damn brittle and tends to crack when you do.
    04 Comp G.
  6. #6 Re: How to remove "Upper Trim Panel" on the dash?
    Jul 2015
    USA
    Cool, just what i wanted to hear. I'm not worried about it breaking. Thanks
  7. #7 Re: How to remove "Upper Trim Panel" on the dash?
    May 2016
    Lincoln, Nebr
    So the entire upper dash trim (no HUD type) just pulls off from clips, similarly to the radio bezel? No bolts or anything...just pull up on it?
  8. #8 Re: How to remove "Upper Trim Panel" on the dash?
    Enfield, CT
    Yes but do it carefully otherwise **** will crack like red said.
    Sent from my LG G3
  1. Can't remove plastic "nut" holding spare tire in well.
    By clagrow in forum General Tech Discussion
    Last Post: 01-06-2013, 01:08 AM
  2. how to remove "Service Tire Monitor System"
    By 04GT in forum 04+ Specifics
    Last Post: 12-20-2011, 10:13 AM
  3. Weird "creaking?" noise from dash
    By NovoGTP in forum General Tech Discussion
    Last Post: 05-06-2011, 02:04 PM
  4. "Chirping" in door panel (squeaks)
    By harrydunn in forum General Tech Discussion
    Last Post: 06-06-2009, 01:03 PM
