Thread: reverse lights on with hazards?
Results 1 to 5 of 5
  1. #1 reverse lights on with hazards?
    May 2008
    Winnipeg, MB
    What kind of modification would it take to make the the reverse lights blink along with the other lights when you put your hazards on?
    2007 Pontiac Grand Prix
  2. #2 Re: reverse lights on with hazards?
    Pennsylvania, USA
    I'd just solder a jumper wire from the positive lead on the brake lights to the reverse lights, with a diode in line to only allow the current to travel from the brakes to the reverse lights, otherwise the brakes will come on with the reverse lights.
    For thine is the Cam, The Piston, and The Rod, Forever and ever (or until they break). Amen.
  3. #3 Re: reverse lights on with hazards?
    Jul 2010
    Coquitlam,BC,Canada
    I would check with your local laws on rear-ward lighting. Rear facing white lights are not cool to people driving behind you; makes for confusion, which = accident.
    And if you use the above method, you will have flashing white lights, which is even more confusing. LOL
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  4. #4 Re: reverse lights on with hazards?
    May 2008
    Winnipeg, MB
    Then when I use the brakes my reverse lights would be on, not good when waiting in traffic.
  5. #5 Re: reverse lights on with hazards?
    Jul 2010
    Coquitlam,BC,Canada
    Quote Originally Posted by tod1d View Post
    You got it.
    You could wire it this way, but put a switch on it so you have full control. Might be able to access the wires at BCM?
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  1. LED reverse lights?
    By Jtiger360 in forum Introductions/Noob Questions
    Last Post: 01-13-2013, 06:36 PM
  2. 04+ HID Reverse Lights
    By Dthreap in forum 04+ Specifics
    Last Post: 03-22-2012, 10:28 PM
  3. Replies: 1
    Last Post: 02-25-2012, 10:34 AM
  4. trunk/reverse lights...
    By popnajera in forum General Tech Discussion
    Last Post: 01-09-2012, 09:34 AM
  5. Reverse lights
    By KR1ST1N_X3 in forum Visual/Body Modifications
    Last Post: 04-15-2009, 08:10 PM
