Thread: headlight wiring issues.
Results 1 to 3 of 3
  1. #1 headlight wiring issues.
    GTP Level Member 04lss's Avatar
    Sep 2014
    Richmond Virginia
    Hi, So i finally got my new (to me) GTP home yesterday.
    I was checking out the headlights, as i knew the high beams didn't work.
    It looks like the wireing harness was hacked up to install the "Halo projector kit".
    I can get replacement ballast/bulbs pretty cheap, but id like to go back to the stock headlights to draw less attention from local law enforcement.
    How hard would it be to get a new headlight harness from the junkyard and rewire it? I have basic soldering skills, but i dont want to get in over my head.
    Thanks!
  2. #2 Re: headlight wiring issues.
    Mar 2012
    NC
    If you can solder, you'll be fine. However, IIRC, the headlight harness has a lot of wires in it. Probably just replacing the damaged areas would suffice...it's what...3 wires per light?
  3. #3 Re: headlight wiring issues.
    Sep 2014
    Richmond Virginia
    I think im just going to buy new ballasts for now, Get my old man to check it over and see if it can pass state inspection. If not i guess ill be spending a few hours undoing the damage.
    the lights do look sweet...
  1. Need help! headlight wiring, hid issue
    By TeacherCreature in forum General Tech Discussion
    Last Post: 06-21-2013, 09:57 AM
  2. Headlight wiring harness
    By mthorn11 in forum Shops and Community Heroes
    Last Post: 01-16-2013, 02:39 PM
  3. headlight wiring
    By hecrum in forum Visual/Body Modifications
    Last Post: 02-10-2011, 11:48 AM
  4. Headlight Wiring Schematic?
    By singularity in forum General Tech Discussion
    Last Post: 09-04-2009, 01:36 PM
  5. headlight/HID wiring
    By GOINDEF in forum Visual/Body Modifications
    Last Post: 04-28-2008, 10:34 AM
