Went to the store and got new resistors. Tested them with a multi meter and got 6.5 ohm hooked black to black and red to green/yellow. One thing to note is I am installing them on the male side of the connector to unplug the headlight. Shouldn't have a difference should it? This time I didn't even use those crappy splice things and still got same results. Do you have to have a resistor on each of the 4 turn signals? Or just where you put in a led bulb? Idk how I can wire up a whole audio system no problem and this is causing me so many issues
