Thread: spyder halos problem
Results 1 to 8 of 8
n3on n3rd spyder halos problem 09-04-2014, 08:01 PM
SomeDudeAtHome Re: spyder halos problem 09-04-2014, 08:27 PM
industrialfish Re: spyder halos problem 09-05-2014, 08:48 AM
n3on n3rd Re: spyder halos problem 09-04-2014, 09:09 PM
SomeDudeAtHome Re: spyder halos problem 09-05-2014, 06:18 PM
92builtbird Re: spyder halos problem 09-05-2014, 08:05 PM
n3on n3rd Re: spyder halos problem 09-07-2014, 01:11 AM
91parkave Re: spyder halos problem 09-05-2014, 09:17 PM
  1. #1 spyder halos problem
    Sep 2014
    Saskatchewan eh!
    I got these halos installed into my 05 gxp, and for some reason they dont work properly.. i didn't wire them myself as im not too familiar with it. But they will randomly turn on then off again.. currently the right side rings work but the low beam doesn't. And the left side low beams work but the rings don't. about a week ago it was completely reversed. random lights will randomly work sometimes then stop working a couple days later. It's really annoying and i dont want any ticket's cause of it. I would assume it's just a wirring problem, but i wouldn't know where to start fixing it. I don't no much about how they are wired so i want to soak in as much info about it as possible, so i can rewire myself if i need too.
    I was also reading on other threads that disabling my drls would help but i cant find the fuse..
    Any help is appreciated!
  2. #2 Re: spyder halos problem
    GTX Level Member SomeDudeAtHome's Avatar
    Buffalo, NY
    Do you have HIDs and do you know if the halos are wired to the parking lamps? I know the 04+ cars have some weird deal with the DRL but i'm not sure what it is exactly. The general consensus on this board is that those are junk and to either stick with stock or get a retrofit made.
    Black 98 GT bought in summer of 2009 w/28K miles- GTX Rims, Retrofit headlights, tinted tails, 20% tint all around, KYB Excel-G's, WBS Lowering Springs, 33mm Dorman front sway bar, 22mm Addco rear sway bar, BMR trailing arms, BMR STBs front and rear, ZZP control arms, Poly motor mounts, ZZP CAI, Thrasher shift kit
  3. #3 Re: spyder halos problem
    Oct 2011
    Toledo, OH
    Quote Originally Posted by SomeDudeAtHome View Post
    06+ Have DRL. 04-05 should not.
    7"
  4. #4 Re: spyder halos problem
    Sep 2014
    Saskatchewan eh!
    no HIDs and i dont know.. any way that i could tell? Yeah thats what ive been reading.. lol
  5. #5 Re: spyder halos problem
    Buffalo, NY
    I can't help you with the DRL but I'd just follow the wires for the halos and see where they go. They should go to either the ones connected to the headlights or parking lamps. If they are randomly turning off and on they also might not be wrired in right. Loose or something.
  6. #6 Re: spyder halos problem
    Jun 2013
    Metro Detroit
    Spyders suck ass.
  7. #7 Re: spyder halos problem
    Sep 2014
    Saskatchewan eh!
    Quote Originally Posted by 92builtbird View Post
    Spyders suck ass.
    haha apparently..
  8. #8 Re: spyder halos problem
    Arizona
    You "disable" DRL by placing some black tape over your light sensor on the dash
  1. halos for a '05 GP
    By kyliek23 in forum Visual/Body Modifications
    Last Post: 02-12-2013, 07:30 PM
  2. New Halos, Slight Problem
    By JesseSmash in forum Visual/Body Modifications
    Last Post: 08-19-2012, 08:27 AM
  3. LED Halos
    By csssaint12 in forum Visual/Body Modifications
    Last Post: 04-11-2011, 01:12 AM
  4. halos...
    By 99silvergtp in forum Off Topic Discussion
    Last Post: 12-26-2009, 04:40 PM
  5. halos
    By gtpsleeper in forum Audio, Security & Visual Electronics
    Last Post: 06-04-2009, 11:14 AM
