Thread: Upgraded hood props for GTX hood??? Only able to use ONE
Results 1 to 10 of 10
  1. #1 Upgraded hood props for GTX hood??? Only able to use ONE
    GT Level Member Hardonyomom's Avatar
    aurora
    Okay so i got a Gtx hood installed recently but had to use the underhood brackets on the old hood to get the hood props to make the hood stay up. The problem is that there are two and i was only able to use one because of the placement where the hole on the inside right side of the hood is for the intake. My body guy was too afraid to drill it bigger and put the hood bracket in. I know it can prob be done but is there an upgraded hood prop i can use that has more power than the stock one? I am currently only using one on the left side and it isn't enough. My girlfriend has a 06 impala and it only uses one so i know it has to be possible. I just Don't want to play the guessing game. Thanks
    F body Front, GXP rear brakes, SSC, Poly Dogbones, SLP Gen 1 spoiler, Gpo's, GTX hood, SD Air dam, LED tails, badges and decals, Comp G Seats,
    FSIC, Ported and painted Gen 3, ZZP LIM, SD Headers, REmoddified ZZP fuel rail, 60 lb injectors, LS7 lifters, 1.9 modded rockers, 2.6 pulley E85, 21 degrees timing -Timboku tuned
  2. #2 Re: Upgraded hood props for GTX hood??? Only able to use ONE
    pictures not sure what your talking about. The latch bracket thats in the middle of the rad support?
  3. #3 Re: Upgraded hood props for GTX hood??? Only able to use ONE
    aurora
    no, the props that hold the hood. they are on each side of the hood by fenders. I think they are hydro and clip in. I am looking for a more powerful one than stock so i can get away with just using one on the left only
  4. #4 Re: Upgraded hood props for GTX hood??? Only able to use ONE
    you mean the hood strut? the piston that holds the hood open?
  5. #5 Re: Upgraded hood props for GTX hood??? Only able to use ONE
    aurora
    Yes , its called lift support on rockauto. I should of went there first.
    Monroe PN 901356 10.28
    AMS AUTO PN 4295 12.36
    AC Delco PN 510374 20.79
    Which one is best? Im guessing the more expensive one?
  6. #6 Re: Upgraded hood props for GTX hood??? Only able to use ONE
    i bet it dont really matter. im sure mine are 16 years old and still work fine today. same for the trunk lifts.
  7. #7 Re: Upgraded hood props for GTX hood??? Only able to use ONE
    hangover park IL
    hope it doesnt crack on ya...but id suggest going to the older 97 prop rod if you didnt want to chance folding/cracking the hood.
    ~James~ Psychotic Gearhead
  8. #8 Re: Upgraded hood props for GTX hood??? Only able to use ONE
    aurora
    According to my research i can get by with an 06 impala hood lift rod support.
    Grand prix specs are
    Extended length 21.74 inches
    pounds of force 99
    shaft diameter 6mm
    body diameter 15mm
    Impala specs are
    Extended length 21.12 inches
    pounds of force 112
    shaft diameter 8mm
    body diameter 18mm
    They are both 8mm ball socket connection.
    I really see no problem in going to this other rod if it fits. It might only open .5 inches lower than stock but the impala single rod opens up my girlfriends hood just fine and it only uses one and the hood is metal. Mine is fiberglass. There is a chance that maybe all i need is a new hood prop that has all the juice in it to handle it .
  9. #9 Re: Upgraded hood props for GTX hood??? Only able to use ONE
    SWPA
    My Grand Prix only has/had one rod from the factory. I pulled it off because it bowed the Inferno hood slightly with it closed.
    I don't know how heavy the stock 97-03 hood is, but I would bet you the Inferno hood is just as heavy, if not heavier than the factory metal hood.
  10. #10 Re: Upgraded hood props for GTX hood??? Only able to use ONE
    aurora
    You think i could get the same rod as a 04 plus? I'm thinking of just getting a new lift support and try using one instead of two. I think a new one even though it requires two, might be just enough to keep it up
  1. Hood ideas for replacement hood
    By KoldAsIce in forum Visual/Body Modifications
    Last Post: 04-15-2013, 06:44 PM
