Thread: How do I remove the middle door molding? 97-03
Results 1 to 6 of 6
  1. #1 How do I remove the middle door molding? 97-03
    GT Level Member TheDarkAngel's Avatar
    Oct 2013
    Iowa
    I just want to remove it to repair it, it's hangin off big time, and I just want to get it back flush. I will take it off, and put some 3M double face tape on it, but I obviously need to get it off first. Is it just clips? or is it something more difficult?
    First car- 1999 Buick Regal LS (Sold)
    Current ride- 2000 Grand Prix GT (The Dark Angel) DIY Intake, flipped bushings, visual stuffs, lowered on Eibachs, Topswap loading...........
  2. #2 Re: How do I remove the middle door molding? 97-03
    GT Level Member Hardonyomom's Avatar
    aurora
    I am not sure about that and i have always wondered myself. I think it is bolted in from the inside of the door panel though but i'm sure somebody else will chime in on it
    F body Front, GXP rear brakes, SSC, Poly Dogbones, SLP Gen 1 spoiler, Gpo's, GTX hood, SD Air dam, LED tails, badges and decals, Comp G Seats,
    FSIC, Ported and painted Gen 3, ZZP LIM, SD Headers, REmoddified ZZP fuel rail, 60 lb injectors, LS7 lifters, 1.9 modded rockers, 2.6 pulley E85, 21 degrees timing -Timboku tuned
  3. #3 Re: How do I remove the middle door molding? 97-03
    Oct 2013
    Iowa
    Well it's just going to be a day of working on it (it is a Grand Prix so no surprise.) I'd just like to know so I can check that off.
  4. #4 Re: How do I remove the middle door molding? 97-03
    GT Level Member lewis1952's Avatar
    Sep 2013
    tulsa okla
    I just removed the molding off my 2000 SE. It's just adhesive. Use a thin plastic putty knife NOT metal. What looks like bolts are just guide pins. Do not pull on the molding it will snap into. Once it's off wet the residue with paint thinner and gently using the putty knife begin pushing the residue. It will roll up.
  5. #5 Re: How do I remove the middle door molding? 97-03
    Jan 2014
    AR
    Its mounted with tape only, but it may still have a locating pin on the back which corresponds to a hole in the sheetmetal. No threads involved. I use a plastic wedge to remove, or a snap knife and a little water to lube the blade if the tape is still gooey not crusty.
  6. #6 Re: How do I remove the middle door molding? 97-03
    Oct 2013
    Iowa
    Ok, thanks guys. I'm just sick of looking at it hanging off lol. I'll update if I don't break it in half.
  1. door molding
    By skip schroeder in forum Introductions/Noob Questions
    Last Post: 08-05-2013, 10:39 PM
  2. How to remove the clips for the lower door molding retainer strip?
    By sschering in forum Visual/Body Modifications
    Last Post: 04-22-2013, 03:00 PM
  3. how 2 remove the rocker molding on a 02 GT
    By 13781verona in forum General Tech Discussion
    Last Post: 12-02-2011, 10:26 PM
  4. Anyone take off the door molding?
    By bandits grand prix in forum Visual/Body Modifications
    Last Post: 09-11-2011, 08:48 PM
  5. about door molding????????
    By jerZcavy4120 in forum General Tech Discussion
    Last Post: 11-02-2010, 01:10 AM
