Thread: Final Thoughts on a Set of Headlights??
Results 1 to 11 of 11
mountcody5 Final Thoughts on a Set of... 04-07-2014, 01:29 PM
Russosaur Re: Final Thoughts on a Set... 04-07-2014, 01:37 PM
mountcody5 Re: Final Thoughts on a Set... 04-07-2014, 01:44 PM
The Guz Re: Final Thoughts on a Set... 04-07-2014, 03:19 PM
Odi Re: Final Thoughts on a Set... 04-07-2014, 03:24 PM
SomeDudeAtHome Re: Final Thoughts on a Set... 04-07-2014, 04:03 PM
sjw515 Re: Final Thoughts on a Set... 04-07-2014, 04:07 PM
The Guz Re: Final Thoughts on a Set... 04-08-2014, 12:51 AM
Odi Re: Final Thoughts on a Set... 04-08-2014, 02:56 PM
bg138287 Re: Final Thoughts on a Set... 04-08-2014, 08:41 AM
Russosaur Re: Final Thoughts on a Set... 04-08-2014, 03:35 PM
  1. #1 Final Thoughts on a Set of Headlights??
    Apr 2014
    Howell, MI
    I have been looking for a new pair of after market headlights for months now, and I have finally come to a conclusion of getting these Spyder Headlights:
    http://www.amazon.com/Spyder-Auto-PR.../dp/B005R4LCBK
    Any body have any review for these? Does anyone have these?
    Thanks for everyones help!
  2. #2 Re: Final Thoughts on a Set of Headlights??
    Moderator Russosaur's Avatar
    Apr 2012
    Dayton, OH
    I haven't had them, I wouldn't recommend them and I'm sure others wouldn't recommend them either. They arn't that good for the money.
    2012 F150 STX
    - Gonna be a race truck
  3. #3 Re: Final Thoughts on a Set of Headlights??
    Apr 2014
    Howell, MI
  4. #4 Re: Final Thoughts on a Set of Headlights??
    Dec 2008
    Lawndale, CA
    First one's have horrible light output. Stay away from those. The second set will have horrible light output since they are tinted. I would either pick up a set of stock replacements or have Classy Pontiac retrofit a set for you with the right projector.
  5. #5 Re: Final Thoughts on a Set of Headlights??
    Donating User Odi's Avatar
    Chicago South Suburbs
    Brackets on those projectors suck big penis. Those are the ones people most commonly buy because they dont look like a bug (like the first set)
    http://www.amazon.com/Spyder-Auto-PR...EWTVDE25R79PV0
    But they all suck... The brackets are awful and you need to put weatherstriping under the headlight and around the corner to remedy the issue a bit. If you really want good output, retrofit is the way to go.
  6. #6 Re: Final Thoughts on a Set of Headlights??
    GTX Level Member SomeDudeAtHome's Avatar
    Buffalo, NY
    Like everyone else has said those type of projectors suck. I had them for once summer and immediately took them off and replaced them with retrofits. I love the retrofits and will never replace them. They're really worth the money. And if you don't have the money just save for a bit longer. It'll be worth it.
    Black 98 GT bought in summer of 2009 w/28K miles- GTX Rims, Retrofit headlights, tinted tails, 20% tint all around, KYB Excel-G's, WBS Lowering Springs, 33mm Dorman front sway bar, 22mm Addco rear sway bar, BMR trailing arms, BMR STBs front and rear, ZZP control arms, Poly motor mounts, ZZP CAI, Thrasher shift kit
  7. #7 Re: Final Thoughts on a Set of Headlights??
    Dec 2012
    Raleigh, North Carolina
    These are the only aftermarket ones i would buy.. but thats just my opinion
    http://www.protuninglab.com/97pogrpreucr2.html
  8. #8 Re: Final Thoughts on a Set of Headlights??
    Dec 2008
    Lawndale, CA
    Quote Originally Posted by sjw515 View Post
    I would even buy those. The chrome reflector is smaller making light output horrible. Your best bet if you want black headlights like these is to get an OEM style one, open them up and paint them to look like the black headlights.
  9. #9 Re: Final Thoughts on a Set of Headlights??
    Quote Originally Posted by The Guz View Post
    That and the price posted for these is ridiculous. 159 dollars for standard headlights that were cracked open and someone wiped off the extra chrome off the housing.
  10. #10 Re: Final Thoughts on a Set of Headlights??
    SE Level Member bg138287's Avatar
    Oct 2012
    St. Cloud, MN
    Man I wish there were some decent aftermarkets for our cars...
  11. #11 Re: Final Thoughts on a Set of Headlights??
    Apr 2012
    Dayton, OH
    OP the best options are the 60$ Stock Replacments, or fork out the dough for retros. And those are pretty much the best bang for buck options. Unless you wanna be a dbag like me and run HIDs in your stock reflector housings.
    2012 F150 STX
  1. Update.... New video.. Read last post... Final thoughts
    By GTPSHAWTY in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-16-2012, 09:29 AM
  2. Thoughts/ Anyone with these headlights?
    By 3CLiPSE in forum Visual/Body Modifications
    Last Post: 05-07-2012, 08:38 PM
  3. the final chapter of my gtp
    By DWosik13 in forum Off Topic Discussion
    Last Post: 06-15-2009, 11:32 PM
  4. thoughts on headlights
    By 99gpse in forum General Tech Discussion
    Last Post: 12-19-2008, 01:03 AM
