Thread: Spyder Projector Lights
Results 1 to 9 of 9
  1. #1 Spyder Projector Lights
    Aug 2012
    Saskatoon, SK, Canada
    Anyone else have these? I need to know a couple things and Spyder's tech dept hasn't been much help at all.
    First off, is there a way to adjust the high beam angle independently of the projector angle? Whenever I get my projectors (which are my low beams only) to a good height, my brights are at an angle that lights up the tree tops.
    Second, the high beams are horrible. I can barely see with them on. Went to the store and the guy said PIAA bulbs are awesome, but he can't guarantee that they'd be much better than what I have already after he looked at my high beams. Has anyone swapped these and noticed a considerable difference? I'm just using the bulbs that came installed in the enclosure.
    Lastly, I've had issues with these bouncing around. Eventually, their frames loosen up so badly that I can see the light bouncing around on every sign that I pass. I'm sure it's very annoying for drivers that have to see it, plus it drives me nuts. Any tips on how to reinforce the frame so they don't bounce and go out of alignment?
  2. #2 Re: Spyder Projector Lights
    Moderator DanPrixGTP's Avatar
    Jun 2011
    Grand Rapids, Michigan
    For bouncing issues, put a strip of weather stripping underneath each headlight.
    When it comes to light output, just get a set of HIDs from VVME. Go with 4300 or 5k as those will be the brightest. Dont worry about getting high beams with HIDs, the single beam will be plenty bright.
  3. #3 Re: Spyder Projector Lights
    Aug 2012
    Simple yet effective solution. I love it. I rolled around just using my projectors for the longest time anyway. I'm assuming since you're recommending them, VVME HID's are good? Can you quickly give me a rundown on what the difference is between their entry level, digital slim, and 12V models is?
    EDIT: Their price defintiely appeals to me, as I was quoted $180 for HID's locally.
  4. #4 Re: Spyder Projector Lights
    Jun 2011
    The majority of people on this forum run either VVME or DDM. Both are good HIDs but the issue with DDM, is the shipping is horrendous - takes forever. A lot of people also run Ebay HIDs such as Xentec, but those are hit or miss. Some people have good luck with those, while me, on the other hand, have gone through 3 sets and finally gave up. I currently have VVME 6k headlights on my Spyder projectors and foglights and they are very bright with no issues. No light output issues either. Well worth the money. I've always stuck with 35w HIDs as those are plenty bright and I believe 55w is overkill. I've had both single beam and high beam headlights. Don't even bother with the high beam HIDs - not worth it. Just buy the normal 12v 35w single beam HIDs from VVME and you'll thank me later.
    Keep in mind, the lower the Kelvin number the brighter they are. (Besides 3K as those are yellow). 4300k will be the brightest while 10k+ makes it look like you're driving underwater. Get some where inbetween 4300k and 6k for color temperature.
    As I stated earlier about the weather stripping under each headlight. It will obviously changed the projector angle (upwards), just a bit, so keep that mind. And it won't totally cure the bouncy issue but it will make a huge difference.
  5. #5 Re: Spyder Projector Lights
    Aug 2012
    Alright dude thanks for the info. I think I'll be grabbing some 35W's, just gotta figure out the color.
  6. #6 Re: Spyder Projector Lights
    Dec 2008
    Lawndale, CA
    I use to own these and ended up going back to stock. They were ok in terms of functionality. The highs can not be adjusted separately. Adjust them for the lows and be done with it. Don't even try to adjust for the beams crossing. If you do, you will end up with gaps. I found the high beams to be worthless and did not even bother with them. If you want to take advantage of the light output of these, get some 5000K HIDs. There are many ways to limit the bouncing. I never got rid of mine after all of the mods to it. Be sure to not over tighten the bracket. They are not the same as the stock bracket.
  7. #7 Re: Spyder Projector Lights
    SE Level Member Jake U's Avatar
    Apr 2013
    Waukesha, WI
    Same^^ I had some spyders for about 3 weeks before I took them out. I couldnt run HID in them without "hotspot" and my cutoffs were at like a 20* angle which made them worthless at night. I put my stock back in and I'm now running 55w 8000k HID.
  8. #8 Re: Spyder Projector Lights
    GT Level Member Points70's Avatar
    Nov 2010
    Bellevue, Nebraska, United States
    I bought an extra set of HID's 6000K for my high beams as well as rewiring some stuff to make my low and high beams be on at the same time when I turned on my High beams since they are two separate bulbs in the spyder headlights. And this makes the light out put amazing with the High beams on.
  9. #9 Re: Spyder Projector Lights
    Moderator Russosaur's Avatar
    Apr 2012
    Dayton, OH
    But that kills the lifespan of your ballasts. Because you can't keep your highs in all the time to keep the bulbs warm. So they always have to re warm up when you turn them off for a passing car. Also flashing high beams would be useless. I have vvmes and had to replace a ballast because salt spray go in it and shorted it out. If I did it again I would got with DD or TRS if I ever get projectors which probably wont happen.
    Sent from my Galaxy Tab 3
    2012 F150 STX
    - Gonna be a race truck
  1. Why Spyder Projector Headlights SUCK!!!!!!
    By buickman104 in forum The Rant Forum
    Last Post: 03-09-2012, 11:06 AM
  2. Spyder Projector Lighting
    By Bedwards in forum Visual/Body Modifications
    Last Post: 05-06-2011, 10:31 AM
  3. Hid With spyder projector headlights
    By shawnschuldt in forum Visual/Body Modifications
    Last Post: 01-07-2011, 09:50 AM
  4. Group Buy Update (Spyder Auto Projector Head lights)
    By john@SpyderAuto in forum Visual/Body Modifications
    Last Post: 04-30-2008, 04:31 PM
