Thread: Just replaced a door, 98 coupe... issues followed...
Results 1 to 5 of 5
  1. #1 Just replaced a door, 98 coupe... issues followed...
    Donating Users joshuaandrew92's Avatar
    Jul 2010
    Bluffton, IN
    The original drivers side door on my 98 coupe was all banged up from a hit and run, so today I decided to replace it. I got the new one installed and bolted up and it opens and closes just fine and it does not seem to sag a whole lot... The problem I am having is that although the door latches, it does not close all the way. I can tell because it looks like the door is still cracked open a bit when closed and I can see the daylight through the weather stripping from inside the car... Is there any kind of adjustment that can be done so that way it shuts completely and seals correctly??? Any and all input/suggestions would be greatly appreciated! thanks!!
  2. #2 Re: Just replaced a door, 98 coupe... issues followed...
    Dec 2012
    Where 4T65E's were born
    There is slop on the door hinges before you tighten them, I'd suggest having someone hold the door level while tightening the bolts, and see what position works.
    Sold.
  3. #3 Re: Just replaced a door, 98 coupe... issues followed...
    Jan 2012
    Philadelphia
    You may have to adjust the striker, thats the piece on the inside of your door jamb if its not closing all the way you might have to move it IN
  4. #4 Re: Just replaced a door, 98 coupe... issues followed...
    check the latch area on the door, it maybe adjustable.
  5. #5 Re: Just replaced a door, 98 coupe... issues followed...
    Jul 2010
    Bluffton, IN
    The latch seems to work fine though it does seem a little loose
  1. replaced cps: still having same issues
    By tai27yiuop in forum Engine
    Last Post: 04-05-2013, 05:34 PM
  2. replaced head gaskets...issues putting back together
    By Cletz in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-11-2012, 06:49 PM
  3. replaced MAF sensor, still got a couple issues.
    By AH06GrandPrix in forum General Grand Prix Discussion
    Last Post: 09-04-2012, 05:24 PM
  4. Replaced Hub Bearings and CV axles. Now I have a host of issues
    By BLK 97 GT in forum General Grand Prix Discussion
    Last Post: 08-11-2012, 08:42 PM
