Thread: "High Beam" options, well more flash to pass
Results 1 to 16 of 16
  1. #1 Re: "High Beam" options, well more flash to pass
    GT Level Member cmal37's Avatar
    May 2011
    Tampa FL near USF
    I have hids in the headlight and fog light place so flashing them isn't really a good idea.
    And I have no flash to pass because I have no highbeams.
    I'm just looking for a more fun solution. But as of right now it looks like im gonna wire the flash to pass into the parking lamps. Or fogs set behind my bottom grill
    Sent from my Lumia 900 using Board Express
    GMPP Struts, F body brakes, CAI, Ubend, resonator, and cat delete, 180tstat, SD headers, 3.4 Pulley, OverKill PCM,http://www.grandprixforums.net/my-bl...res-60017.html
  2. #2 Re: "High Beam" options, well more flash to pass
    Jul 2010
    Coquitlam,BC,Canada
    Quote Originally Posted by cmal37 View Post
    So they say. Been doing it for 10 years now with no ill effects.
    Right. You can do "off/on" instead of "flash".
    Sounds like you have your mind set, so good luck.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  1. Volt gauge reading high, "charging system failure"
    By Aeroheadcww in forum General Tech Discussion
    Last Post: 05-21-2014, 12:03 AM
  2. 2006 Grand Prix "Reduced Engine Power" and "Service Traction System" warnings
    By chadwick in forum General Grand Prix Discussion
    Last Post: 10-04-2013, 09:59 PM
  3. Chug at start, "bouncing" tach when key turned to "on"...
    By KZOO3800 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-21-2011, 10:50 PM
  4. "Edit Options" Inop.
    By SuperSport in forum Forum Bugs/Suggestions
    Last Post: 03-11-2010, 02:47 AM
  5. High beams "point down"
    By palmergg in forum General Tech Discussion
    Last Post: 10-21-2008, 01:13 PM
