Thread: "High Beam" options, well more flash to pass
Results 1 to 16 of 16
  1. #1 "High Beam" options, well more flash to pass
    GT Level Member cmal37's Avatar
    May 2011
    Tampa FL near USF
    So I have HIDs in stock housings, I did not get the duel stage ones though. So I have no high beams. Today however I was thinking on my long drive home, I have no lights to flash. I.e if there is a officer on the side of the road or to let the truck driver know I am letting him in so he wont crush me. So I was trying to think of lights I could add, or modify to do such a thing...
    Goal would be that they only come on when I flash the high beam switch, I have no intent to actually use them as high beams.
    Maybe add fogs behind my bottom mesh grill? or some kind of housing behind the top grills?
    Just kinda fishing for thoughts here or if anyone else has thought the same thing.
    GMPP Struts, F body brakes, CAI, Ubend, resonator, and cat delete, 180tstat, SD headers, 3.4 Pulley, OverKill PCM,http://www.grandprixforums.net/my-bl...res-60017.html
  2. #2 Re: "High Beam" options
    Leave it's is. Learn to hurry up and switch lanes when needed without being crushed. Seriously how often would u be put into that situation. 9/10 you'll have plenty of time to slow down and creep into the other lane. If someone is on the side of the road if not u slow your ass down and let the oncoming traffic past then make a move.
    But I'm guessing your just feeling the need to spend money on something....
    04 Comp G.
  3. #3 Re: "High Beam" options
    May 2011
    Tampa FL near USF
    Lol kinda, im looking for something a little fun and not to expensive I can do in the parking lot of my apartment.
    Was also thinking I could just wire into the parking lamps so they flash when I activate the high beams... But not nearly as different
    Sent from my Lumia 900 using Board Express
  4. #4 Re: "High Beam" options
    Never Be A Tim. ILoveAudi's Avatar
    Aug 2012
    Middle of Nowhere, OH
    Make friends with people that have garages. Lol
    1998 GTP Coupe - DIY Intake, Stock - 178k miles with rusty weight reduction (sold)
    1998 GTP Sedan - CT turbo kit, billet wheel pt61, s1x blower cam, Iceman stage 3 heads, 90# springs for all the valve floatz, walbro pump, fuel pump rewire *slowest s1x build ever*
  5. #5 Re: "High Beam" options
    May 2011
    Tampa FL near USF
    Quote Originally Posted by ILoveGM View Post
    That would be ideal! but all my friends so far also live in apartments :/
    Also I would need money then to do something bigger... Like a cam!
  6. #6 Re: "High Beam" options
    Flash your parking lights.
  7. #7 Re: "High Beam" options
    If it's a must you can just wire up your parking lamps to be your flash to pass in case you do end up needing it
    04 Comp G.
  8. #8 Re: "High Beam" options
    GT Level Member Cocor's Avatar
    Aug 2012
    Collinsville, il
    FYI: if you're signaling an 18 wheeler, don't flash your brights. Just turn them off and on two or three times. It's easier to see the signal and doesn't blind them, giving them purple spots to avoid for the next 10 minutes. As for signaling other drivers about a cop, screw em. If they're dumb enough to drive like an idiot without scouting the area for snakes it the weeds, it's their problem. lol - Problem solved. No high beams needed.
    2005 GP GXP Ivory White, OBX Headers, Cat and Muffler delete, HP Self Tuned, De-badged/Custom LS4 badges, K&N CAI, Intense Poly upper mounts, Strut Tower Braces, HSRK, HID 8000k headlights, Switchback LED front turn signals, interior LED's. Dyno'd @ 275whp/275wtq
  9. #9 Re: "High Beam" options
    Too broken to be broke $$ ntreftz's Avatar
    May 2013
    What the hell is CENLA, Louisiana
    do you not have fog lights? they have a switch??? That's what I do to signal folks
    Poly Uppers, 3.5 snout, HAI, Can Tune, STB, Autolite 606 coppers, 2.5 cattless dp
  10. #10 Re: "High Beam" options
    Pennsylvania, USA
    Retrofit and enjoy lows and highs that are properly aimed. HIDs+stock housings=big blinding blob to every other driver on the road
  11. #11 Re: "High Beam" options
    May 2011
    Tampa FL near USF
    Quote Originally Posted by ntreftz View Post
    I have HIDs there as well, so I used to do that.
  12. #12 Re: "High Beam" options
    GTX Level Member SomeDudeAtHome's Avatar
    Buffalo, NY
    Why not just buy hids that have high beams? If you're only going to use them for flashing and not driving it seems by far the easiest solution. Probably cheaper than trying to build your own lights behind the grills too or something.
    Black 98 GT bought in summer of 2009 w/28K miles- GTX Rims, Retrofit headlights, tinted tails, 20% tint all around, KYB Excel-G's, WBS Lowering Springs, 33mm Dorman front sway bar, 22mm Addco rear sway bar, BMR trailing arms, BMR STBs front and rear, ZZP control arms, Poly motor mounts, ZZP CAI, Thrasher shift kit
  13. #13 Re: "High Beam" options
    May 2011
    Tampa FL near USF
    Quote Originally Posted by SomeDudeAtHome View Post
    See that would be a simple, way less fun option. I have no need to actually have high beams, more just to have the flash to pass option back
  14. #14 Re: "High Beam" options
    Jul 2010
    Coquitlam,BC,Canada
    OP, you have several options right in front of you.....
    Headlights, manually "flash" them off/on.
    Headlights, flash to pass as you normally would.
    Foglights, manually "flash" them off/on.
    All three above will allow you to flash to pass, by you making the lights switch off and on quickly.
    I use my fogs for said feature, off/on twice, repeat as necessary.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  15. #15 Re: "High Beam" options, well more flash to pass
    May 2011
    Tampa FL near USF
    I have hids in the headlight and fog light place so flashing them isn't really a good idea.
    And I have no flash to pass because I have no highbeams.
    I'm just looking for a more fun solution. But as of right now it looks like im gonna wire the flash to pass into the parking lamps. Or fogs set behind my bottom grill
  16. #16 Re: "High Beam" options, well more flash to pass
    Jul 2010
    Coquitlam,BC,Canada
    Quote Originally Posted by cmal37 View Post
    So they say. Been doing it for 10 years now with no ill effects.
    Right. You can do "off/on" instead of "flash".
    Sounds like you have your mind set, so good luck.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  1. Volt gauge reading high, "charging system failure"
    By Aeroheadcww in forum General Tech Discussion
    Last Post: 05-21-2014, 12:03 AM
  2. 2006 Grand Prix "Reduced Engine Power" and "Service Traction System" warnings
    By chadwick in forum General Grand Prix Discussion
    Last Post: 10-04-2013, 09:59 PM
  3. Chug at start, "bouncing" tach when key turned to "on"...
    By KZOO3800 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-21-2011, 10:50 PM
  4. "Edit Options" Inop.
    By SuperSport in forum Forum Bugs/Suggestions
    Last Post: 03-11-2010, 02:47 AM
  5. High beams "point down"
    By palmergg in forum General Tech Discussion
    Last Post: 10-21-2008, 01:13 PM
