Thread: Steering wheel swap 97 to 2001
Results 1 to 5 of 5
  1. #1 Steering wheel swap 97 to 2001
    Banned
    Jan 2013
    maryland
    I wanted to know is it possible to swap a 2001 wheel into a 97 grand prix? If so would It be bolt in? Any insight would help being as I want to swap the 2 I prefer the 2001 style better
    Sent from my SAMSUNG-SGH-I747 using Tapatalk 2
  2. #2 Re: Steering wheel swap 97 to 2001
    Air bag would be the biggest question. If they changed the systems and if it's compatible.
  3. #3 Re: Steering wheel swap 97 to 2001
    Banned
    Jan 2013
    maryland
    Ok I'll check out the diagrams.. thanks
  4. #4 Re: Steering wheel swap 97 to 2001
    the plugs on the clock spring maybe different. so you may need to swap to that newer year clock spring, then cut the cars factory plug off and solder the new matching year on there.
  5. #5 Re: Steering wheel swap 97 to 2001
    GT Level Member douger's Avatar
    Aug 2012
    Fort Wayne
    Programming the BCM?
    There's no sense spending money on a project like this if there's a hurdle you can't surmount. Metra's solutions may be more satisfying.
  1. Steering wheel swap?
    By DougE in forum Audio, Security & Visual Electronics
    Last Post: 08-22-2012, 03:36 AM
  2. 2001 GTP steering wheel controls and fac amp install double din?
    By blazed16 in forum Audio, Security & Visual Electronics
    Last Post: 03-15-2012, 07:49 PM
  3. Steering Wheel Swap 97-03 to 04+?
    By Cbierniat24 in forum General Tech Discussion
    Last Post: 03-20-2011, 06:44 PM
  4. Steering Wheel Swap
    By pski920 in forum Visual/Body Modifications
    Last Post: 05-31-2009, 03:48 PM
