Thread: Steering Wheel Swap 97-03 to 04+?
Results 1 to 2 of 2
  1. #1 Steering Wheel Swap 97-03 to 04+?
    SE Level Member Cbierniat24's Avatar
    Mi
    I was at a local junkyard and saw they had quite a view newer model grand prixs and wondered if a steering wheel swap would be possible. Has anyone attempted this and can you keep the radio controls?
    Theres also a 07 Monte Carlo SS which Im taking the struts from
  2. #2 Re: Steering Wheel Swap 97-03 to 04+?
    SE Level Member Mike Kopstain's Avatar
    Chicago, IL
    I would imagine it would be pretty straight forward. The W Body parts were swapped along so many different models that they tried to keep each model as generic as possible. There's a good chance it will just pop right on. If not, check the wiring of each clock spring and swap wires as necessary.
    Physically it should fit just fine though.
    Thinking about shopping with ZZP or the other guys? - Order with us instead and we'll give you a 5% off coupon code for your next order! Click here to learn how!
    Like us on Facebook!
  1. Steering wheel...
    By SiDeWaYz in forum Visual/Body Modifications
    Last Post: 07-21-2010, 10:45 PM
  2. Steering Wheel with LED
    By jcl1 in forum Visual/Body Modifications
    Last Post: 10-25-2009, 10:35 AM
  3. Steering Wheel Swap
    By pski920 in forum Visual/Body Modifications
    Last Post: 05-31-2009, 03:48 PM
  4. Steering wheel swap 04-08 W/radio controls
    By michaelbm in forum General Tech Discussion
    Last Post: 03-29-2009, 11:19 PM
