Thread: Replacement passenger rear view mirror
Results 1 to 9 of 9
  1. #1 Re: Replacement passenger rear view mirror
    Sure can but you'll want to wetsand, compound, polish. Don't use that Duplicolor perfect match crap. Get some body color paint in a aerosol can either from the dealer, or Sherwin Williams can mix some for you if you give them your paint code or my favorite...automotivetouchup.com
    Once you remove the door panel. Should be 3 either 10 or 13mm nuts holding the mirror housing.
    04 Comp G.
  2. #2 Re: Replacement passenger rear view mirror
    Jul 2010
    Philly
    Thanks, yeah I wanna do all that. Never done it before and this should be a easy project to jump into it with. Is there a write up I can follow for doing the painting? Think 1 12oz can will do the job? Do I gotta clear coat it after the fact?
  1. Passenger Side Rear View mirror
    By Tim 2000 in forum General Tech Discussion
    Last Post: 01-03-2009, 05:27 PM
