Quote Originally Posted by burgundybullet View Post
If you are serious about wiring them I would suggest cutting the stock bulb plug and wiring them straight up to that using a 12v LED strip. Ill poke around and see If I can find something that would work for you.
Ditto. The plan in my head was to re-use the light sockets to power an LED strip, but also use the sockets as a holder or mount, so the LED strip could be installed from the trunk, same as swapping the bulbs.
You can also take an old bulb, remove the glass and solder wires to the base. I did similar on my fogs.....
