Thread: New and confused on what to do with my cars rust problem
Results 1 to 10 of 10
  1. #1 New and confused on what to do with my cars rust problem
    May 2013
    Minnesota
    Hello all i have a 1998 Grand Prix GTP. The rockers are all gone. its not a pretty sight underneath the car. yesterday i saw a piece of rust hanging underneath it. i grabbed it and it broke off it was the pinch weld's i believe their called. their all gone on the passenger side the drivers side pinch weld's are pretty much crushed from someone jacking the car up. honestly i wish i looked over the car more cause i only had it for a few months. i am just trying to see what you guys think i should do. cause their is rust everywhere. the middle of the car where the exhaust runs looks the best. the trailing arms all have surface rust i believe. i can get some pictures if that helps. i honestly just feel like selling it cause it sounds like one big headache.
  2. #2 Re: New and confused on what to do with my cars rust problem
    Drive it until it falls in half. This is rust.
  3. #3 Re: New and confused on what to do with my cars rust problem
    GT Level Member Utter99's Avatar
    Warsaw indiana
    Dan your car should of been in the book of world records .
    MY LUGNUTS REQUIRE MORE TOURQE THAN YOUR HONDA PUTS OUT!!!
  4. #4 Re: New and confused on what to do with my cars rust problem
    GT Level Member Shiftingshaddow's Avatar
    KC
    its a lot of dollars to fix the rockers and pinch welds if you have someone else do it. if you can do it its a lot of work. either live with it or sell it. those are pretty much your options. fixing those rockers is more than the car is worth
    2001 GTP Special Edition
    ZZP DP with Cat, Open Cone Intake, ZZP 1.0 PCM, 3.4 pulley, AL 104s, Rocker Panel Delete.....
  5. #5 Re: New and confused on what to do with my cars rust problem
    May 2013
    Minnesota
    Is there any safety issues if I keep driving it? I noticed its rust by the front strut towers too. I wonder why this happens? It's sad the whole repair is worth more than the car.
  6. #6 Re: New and confused on what to do with my cars rust problem
    KC
    the strut towers is a safety hazard if they get too bad. if its just surface rust then maybe you can sand it and paint it or something to slow it down. I thought they used sand on the roads in mn, not salt? the other rust doesn't affect anything, though.
  7. #7 Re: New and confused on what to do with my cars rust problem
    Last time I knew MN used tons of salt.
  8. #8 Re: New and confused on what to do with my cars rust problem
    Quote Originally Posted by Utter99 View Post
    It's in my book of world records lol. I'll miss that car greatly but once the comp g is back together the hurt will lessen.
  9. #9 Re: New and confused on what to do with my cars rust problem
    KC
    Quote Originally Posted by slick2500 View Post
    I don't know. I just know when it gets too cold here in kc they don't use salt, they use sand because the salt isn't effective below a certain temp. MN is generally colder than KC for a longer period of time and gets the more extreme cold for longer periods. I thought I had heard some people from Minnesota say they don't use salt up there.
  10. #10 Re: New and confused on what to do with my cars rust problem
    May 2013
    Minnesota
    I wish I knew what they used but I noticed in the winter my car gets white in some areas. I thought that is from the use of salt?
  1. Rust Problem
    By tigers40 in forum General Grand Prix Discussion
    Last Post: 06-23-2012, 10:04 PM
  2. Got it and now I'm confused
    By dengnath in forum Audio, Security & Visual Electronics
    Last Post: 10-09-2011, 04:49 PM
  3. I'M CONFUSED! Looking for some help from the pro's
    By rlvis361 in forum Brakes/Suspension/Chassis
    Last Post: 07-13-2011, 08:58 AM
  4. new and confused
    By kellyreap in forum General Tech Discussion
    Last Post: 03-17-2011, 08:35 AM
  5. Confused!
    By tyno59 in forum Visual/Body Modifications
    Last Post: 10-29-2009, 09:17 PM
