Thread: Halo Projector Head lights ? ?
Results 1 to 8 of 8
  1. #1 Halo Projector Head lights ? ?
    SE Level Member GTPJason's Avatar
    Sep 2012
    New Carlisle, OH
    After some searching I couldn't find anything definitive so I'll start a new thread.
    I would like to upgrade my head lights with halo projector type. What are the best ones at a reasonable cost. Are the Ebay ones okay ? Any feedback on those?
    What kind of bulb do you use in the projector?
    Do you need an HID conversion for projectors?
    Thanks
    2000 Pontiac Grand Prix GTP: Black on Black, all stock
    1987 Buick Grand National: 3.8L stock block, Billet Main Caps/ARP studs, GT6776E, 3400 Stall, 55lb injectors, LT1 MAF-Translator, Turbo Tweak chip: 516 FT-LB torque, 16# boost-93 oct
  2. #2 Re: Halo Projector Head lights ? ?
    Yoga city
    retro fit or bust, everyone will tell you this
  3. #3 Re: Halo Projector Head lights ? ?
    Sep 2012
    New Carlisle, OH
    Thanks, Could you explain more please? Retro fit to what?
  4. #4 Re: Halo Projector Head lights ? ?
    Yoga city
    retro fit progectors into your current houseings, you end up with a good progection of light across the road. output from ebay ones just plain out suck.
  5. #5 Re: Halo Projector Head lights ? ?
    West Side Michigan
    Cut your headlights from the back to fit a real projector. It takes work and is not as cheap as just settling for an ebay set BUT, you won't get the output a retro fit provides you with ebay headlights.
    There are about 4 different styles of headlights for our cars (minus the different finishes they come in)
    DO NOT GET THESE (terrible light output)
    1997 2003 Pontiac Grand Prix New Smoke Halo LED Signal Projector Head Lights Set | eBay
    These are what I feel give you the best output:
    97 03 Grand Prix 1 Piece Black Halo Projector Headlights Corner 2in1 Upgrade | eBay
    I had these and they were decent, compareable to above:
    Blk LED Halo Rims Projector Head Lights Lamp Signal 1997 2003 Pontiac Grand Prix | eBay
    The fourth one is just a refreshed design of the above, slightly different, in my opinion, slightly better looking.
    Okay, disclaimer with getting ebay headlights:
    They most likely will bounce (get weather stripping underneath them)
    Output is not the BEST but better then stock
    Mounting brackets are fragile and break easy
    And yes you can wire HID's if you please, not necessary. I'd put HID's in any projectors to get better output. MAKE SURE YOU AIM YOUR HEADLIGHTS CORRECTLY. You don't need to be blinding people.
  6. #6 Re: Halo Projector Head lights ? ?
    Sep 2012
    New Carlisle, OH
    How about these? BLACK 97-03 GRAND PRIX DUAL HALO PROJECTOR HEADLIGHTS w/CORNER LIGHTS LAMPS | eBay
    And will I have to get bulbs for them? Is it plug n play or is there some wiring to do?
    Thanks
  7. #7 Re: Halo Projector Head lights ? ?
    Sep 2012
    New Carlisle, OH
    Thanks for all of that info!! Right now I have the stock housings that are cracked and water logged. I can't even tell a difference between dim and bright. Dims with the fogs on are brighter. I'm just looking for the something that will be an easy replacement with some style and at least stock performance.
  8. #8 Re: Halo Projector Head lights ? ?
    Sep 2012
    New Carlisle, OH
    I like these too. Do these require Balast ? or any other modification?
