The method I use to take it out is: Grab the plastic square around the lens and the pull it to the opposite side of the handle. It will come off pretty easy but if it is the first time taking it off you may need to work it a bit. It also might help to push the square towords the front of the car to make the back little latch pop out and then pull it to the end of the handle. Hope this helps, if you need more help just ask
