Thread: air box
Results 1 to 20 of 27
  1. #1 air box
    GT Level Member 1996pontiac's Avatar
    Livonia, Michigan, United States
    I was wondering what size is the air box going to the tube? i am going to put on a open cone filter.
    1999 Red Pontiac Grand Prix GTP/120xxx miles
    Mods- Intake
  2. #2 Re: air box
    I think it's 3.75 inches
  3. #3 Re: air box
    would you put the filter inside or outside the tube?
    Mods- Intake
  4. #4 Re: air box
    Outside..they usually have ribs on teh inside to seal to a tube
  5. #5 Re: air box
    ok i might as well just put in right on the tb? thats a 4"?
    Mods- Intake
  6. #6 Re: air box
    GTX Level Member Doug 97 gtp's Avatar
    Sep 2011
    palm harbor florida
    put some kind of bend on the intake like a 45 or 60 degree roughly 4-6 inches long
    1997 GTP . repainted in jet black with blue pearl. rebuilt motor
    with vs cam ported heads and blower.
  7. #7 Re: air box
    Sep 2011
    palm harbor florida
  8. #8 Re: air box
    GTX Level Member blackflag's Avatar
    Virginia
    PVC 22.5 bend 4" will work fine
  9. #9 Re: air box
    I went to go put on my open cone on, i went to go remove the air box and there are wires that hook up to the air bix. what do they do and how can i remove them?
    Mods- Intake
  10. #10 Re: air box
    The IAT in the accordian tube?
    Or the PCM in the airbox itself?
    IAT, stuff it in the filter and slap it on the TB.
    PCM...just yank the harness off of the box it is clipped into.
  11. #11 Re: air box
    I think it the pcm. what else would i need to look out for when taking the box out? Im just going to put a cone on the accordian tube
    Mods- Intake
  12. #12 Re: air box
    where would i relocate the pcm?
    Mods- Intake
  13. #13 Re: air box
    Where the airbox was.
    Just leave it there, it doesn't move.
    I did that on both of my WBody's...you're fine.
  14. #14 Re: air box
    Virginia
    Zip ties and weather stripping should cease any rattles you may encounter.
  15. #15 Re: air box
    Quote Originally Posted by BlackFlag View Post
    So its not bolted to the body of the car. its held in by the air box? im confussed.
    Mods- Intake
  16. #16 Re: air box
    Yes.
    The PCM is held in by the airbox.
    Which is bolted the the body.
    So when you remove the airbox, the PCM isn't bolted to anything.
    So just set it there.
    It's fine.
    You're over analyizing this.
  17. #17 Re: air box
    I've changed my opinion on the topic.
    Secure it.
  18. #18 Re: air box
    Quote Originally Posted by 1996pontiac View Post
    correct, the air box is bolted to the car, the pcm just hangs out in there, why, who knows its dumb lol
    mine is also just laying there unsecured, it dont move at all.
  19. #19 Re: air box
    Secure it.
    ***k you.
  20. #20 Re: air box
    Oh yes it does.
    Pick it up and inspect the case.
    Its moving alright.
air, box
