Hi,
I installed these switchback LED bulbs from eBay. I also installed the EP28 flash relay to bypass the hyperflash.
The hyperflash fix works for sure. I tested a before and after. The problem is that the LED lights (with the headlights active) have the white LED on, and the amber just flashes very dimly regardless if the turn signal is on or off. With the turn signal on, the white LEDs would remain on, and still, the amber just flashes (the white kills the usefullness of the amber). A few times with the turn signal on the white LED's were off and the ambers just flashed, but when the turn signal was switched off, the white did not return.
Sorry if im confusing you, but any idea what is wrong? Also, both the turn signal lights in the spedometer cluster were dimly lit and would grow brighter/dimmer randomly. Did i buy junk or am I doing something wrong?
2001 GTP btw
