Thread: HID fog light problem
Results 1 to 8 of 8
  1. #1 HID fog light problem
    GT Level Member hockeybawler's Avatar
    Oct 2011
    huntley
    I have HID fogs and for some reason the passenger side fog light has now burnt out/stopped working twice before my drivers side has burnt out. Another grand prix owner at my work has the same problem, any thoughts on whats causing this? They are both 2004 grand prix's. Thanks for the help in advance!
  2. #2 Re: HID fog light problem
    Are you using a harness for power or the stock wiring?
  3. #3 Re: HID fog light problem
    GTX Level Member Doug 97 gtp's Avatar
    Sep 2011
    palm harbor florida
    if you dont have a harness then they will keep going bad. it happens to alot of people that dont want to buy a 7 dollar wiring harness.
    1997 GTP . repainted in jet black with blue pearl. rebuilt motor
    with vs cam ported heads and blower.
  4. #4 Re: HID fog light problem
    Oct 2011
    huntley
    To be honest I am not sure because the owner before me put them in, what would the harness look like? Also where would it be connected to?
  5. #5 Re: HID fog light problem
    Sep 2011
    palm harbor florida
    the harness connects straight to your battery with an in line fuse not from you oem harness well only one side connects to you oem plug to gain control from your switch the balast connect to the bulb and to a relay and the harness has ground wired for each one. it draws power straight fro your batter making you bulbs brighter and last longer. so if anything goes wrong the will go first instead of your hid componets.
    for your fog light i would reccomend this harness Car HID Xenon Conversion Harness Fuse Relay Wire For H8/H9/H10/H11/880/881 | eBay
    this is the one i got and its made pretty well good connections and evreything is heat shrinked.
    the only thing you might have to do is you might have to lengthen the battery wire because it is a little short
  6. #6 Re: HID fog light problem
    Oct 2011
    huntley
    Oh that actually makes a lot of sense now, I am glad it will also take care of the dumb flickering problem. I am assuming that I will need two of these because my low beams are HID's also, am I correct on this or do I only need one?
  7. #7 Re: HID fog light problem
    Sep 2011
    palm harbor florida
    you need 2 harnesses 1 for headlights and 1 for fogs. the harnesses arent connected to eachother in anyway they are 2 separate wiring looms. the flickering might go away but it couls also be your ballast what kind of hid's do you have?
  8. #8 Re: HID fog light problem
    Oct 2011
    huntley
    I do not remember the brand right off the top of my head but will look tomorrow for sure, thanks for all the help with this
  1. ABS/Trac Light problem
    By Remnant King in forum Brakes/Suspension/Chassis
    Last Post: 06-27-2011, 10:01 PM
  2. light problem
    By SwatRaptor in forum Audio, Security & Visual Electronics
    Last Post: 03-06-2011, 05:38 PM
  3. Fog light problem
    By cloons411 in forum General Tech Discussion
    Last Post: 04-20-2010, 04:14 PM
  4. new to forum with svs light problem
    By jozwhales in forum Introductions/Noob Questions
    Last Post: 07-17-2009, 05:10 PM
  5. light problem!!!!
    By TDCRacing in forum General Tech Discussion
    Last Post: 04-21-2008, 12:11 PM
