Thread: VHT Nightshade or lens tint?
Results 1 to 20 of 21
  1. #1 VHT Nightshade or lens tint?
    GTX Level Member asite57's Avatar
    Oct 2011
    Michigan
    i have some lens tint from autozone and ive used it on several cars it doesnt look bad but its kind of a flat black tint i was looking a VHT Nightsade and that appears to be glossey when applied is this true? i want a glossey tint with out clear coat sould i buy a hole new can of VHT or will it not be my desired effect
    SOLD. 99 GTP - Open Cone, ZZP STB ,GMPP Front & Rear Sway Bar, 3" DP & Cat-Back, Built Trans, 12'' Brakes, Tune
    http://www.grandprixforums.net/gtp-t...ack-67489.html
    04 SRT4 - Bone Stock....For Now
  2. #2 Re: VHT Nightshade or lens tint?
    Jan 2012
    Philadelphia
    my friend tinted his with VHT with no clear coat and it came out nice it was shinny to i dont know how he did it because everyone i seen who used VHT came out flat and dull with no clear i tinted mine with film and they look like this.
    if you use actual tint the lighting will shine through better IMO
  3. #3 Re: VHT Nightshade or lens tint?
    Oct 2011
    Michigan
    those look really good and thats what im pretty much going for
  4. #4 Re: VHT Nightshade or lens tint?
    Dec 2011
    Philadelphia, PA
    throw a few coats if vht in it plus clear coat and it be pretty nice, as long as u prep it right it will come out just fine
    AEM bruteforce intake
    Diablo 93 Octane tune
  5. #5 Re: VHT Nightshade or lens tint?
    Oct 2011
    Michigan
    for prep on other cars i usually just wipe it down with a rag that ive sprayed with brake clean (i never let my cars get dirty) i dont wanna clear coat it because then its harder to remove if i just spray it on there then it come off with carb clean i like always having that as an option
  6. #6 Re: VHT Nightshade or lens tint?
    if you wet sand the vht after its dry and buff it should shine.
    i did 2 coats of vht, and 5 coats of clear wet sanded the clear and buffed them up. 2 coats is not blacked out, but dark cherry look, 3 coats or more and its blacked out good. i wanted my brake lights to be seen during the day time.
    stock daytime lights on
    tinted daytime. no lights.
    and what i got at night.
  7. #7 Re: VHT Nightshade or lens tint?
    part of the prep is to wet sand or Scotch brite pad the lens then clean with a prep spray. tape them off and then spray em. sanding them lets the vht bond better. and they can always be buffed back to a stock shine if you wanted to.
    note how dull the tail light looks.
  8. #8 Re: VHT Nightshade or lens tint?
    Moderator DanPrixGTP's Avatar
    Jun 2011
    Grand Rapids, Michigan
    Use VHT, mine are real shiny. i wet sanded stock lights, then VHT, wet sanded, Ultimate Compound (to get scratches out), 2nd coat VHT, wet sanded, Ultimate Compound, 3rd coat VHT, wet sanded, utimate compound. Then came about 5 coats of clear with wet sanding and ultimate compounded as well. Took me a whole day to do it, but the end results were very good and shiny.
  9. #9 Re: VHT Nightshade or lens tint?
    GTP Level Member joshv's Avatar
    canada
    i have mine tinted with VHT and my cars blak and from some angles it looks just like the black paint thats on the car
    2005 GXP / Cartuning Turbo Kit / meth / Cutout / Ported LS4 intake Manifold / HP Tuned / Custom 3" Cat-Back / Highflow Cat / SSC Springs / Poly Dogbone Mount's / 2nd Tranny /
    ( p/o track time12.6@109mph 1.7 60ft )
  10. #10 Re: VHT Nightshade or lens tint?
    Oct 2011
    Michigan
    dude that looks perfect
  11. #11 Re: VHT Nightshade or lens tint?
    Jun 2011
    in this picture, the right taillight looks exactly like the paint. Very nice
  12. #12 Re: VHT Nightshade or lens tint?
    Houston
    This is 3 coats of Lens Tint, 1 coat clear and buffed.
  13. #13 Re: VHT Nightshade or lens tint?
    USA
    Month of July Flip is tinting GP lights for $50.
  14. #14 Re: VHT Nightshade or lens tint?
    Quote Originally Posted by limegreen View Post
    Bingo! What I would do....avoid VHT is u can and have him tint them.....one of the best mods i've done...VHT can look good if done right but Flip uses actually automotive paint w/ clear and it stands up the the elements just like yours cars paint.
    04 Comp G.
  15. #15 Re: VHT Nightshade or lens tint?
    Sep 2011
    Arkansas
    How does one get in touch with Flip nowadays?
    1978 F250 2wd (460 c.i.d. / C6)- soon to give up the powerplant to an '80-'86 F150
    White 2000 Grand Prix GT coupe
    One still slow and loud... other one scoots just a bit.
  16. #16 Re: VHT Nightshade or lens tint?
    Ohio
    here are some of the sets I have done with VHT
    those started like this
  17. #17 Re: VHT Nightshade or lens tint?
    Yoga city
    gpona.com
  18. #18 Re: VHT Nightshade or lens tint?
    USA
  19. #19 Re: VHT Nightshade or lens tint?
    Yoga city
    both will work prolly do this one though^
  20. #20 Re: VHT Nightshade or lens tint?
    Ontario
    These are mine with VHT. 3 coats of VHT, 5 coats of clear, 2000 grit wet sand, then another 2 beefier coats of clear. Still have to polish and wax one more time. Needs more shiny
  1. VHT Nightshade
    By dwm1975 in forum Visual/Body Modifications
    Last Post: 12-02-2015, 06:19 PM
  2. window tint and maybe tail light tint
    By joeringo11 in forum 04+ Specifics
    Last Post: 02-04-2012, 12:10 AM
  3. Nightshade these Tails? Yes? No?
    By GrandPrixGTP1 in forum Visual/Body Modifications
    Last Post: 06-12-2011, 06:27 PM
  4. tint (people in states where front tint is not allowed at all)
    By gotboost3 in forum Visual/Body Modifications
    Last Post: 08-22-2009, 07:54 PM
  5. vht nightshade
    By kingd44 in forum Visual/Body Modifications
    Last Post: 01-10-2009, 09:16 AM
