Thread: Help with HID'S
Results 1 to 5 of 5
  1. #1 Help with HID'S
    Destroys cars izup69's Avatar
    Iowa
    Ok so I got my hid kit from diode. I hooked everything up and only my high beam halogen light comes on the hid wont turn on. When I turn the bright lights on the halogen light dims. But still no hid lighting up. I didn't know if I had to let the ballast heat up. I had them plugged in for about 3 mins but still nothing. I didn't know if the wiring needed to be spliced or anything with the set from diode. Thanks for any help
    06 base open cone,2.5 inch dp into high-flow cat,window tint,drilled rotors.
    97 GTP ubend delete,drilled and slotted rotors,de-badged,open cone,6k HID,All aftermarket speakers
  2. #2 Re: Help with HID'S
    St. Cloud, MN
    Switch the connector around on the ballast.
  3. #3 Re: Help with HID'S
    GTX Level Member SF9777's Avatar
    Jan 2012
    Anaheim, Ca
    Ya flip around the plugs on the wires and should start working
  4. #4 Re: Help with HID'S
    SE Level Member midrange's Avatar
    Belleville, Ontario
    when you get them working, could I see a pic.. I want to get HID's.
  5. #5 Re: Help with HID'S
    Iowa
    Ok ill post some pics when im done just to make sure I know what ones im flipping here is a pic i got the ones that I think I should flip marked its kinda dark out now and its like 12:30 so I dont think ill do it tonight although I might lol.pic 1.jpg
    (edit) ok thanks for the help guys I got them working by flipping that connector now my fog lights dont work anymore it says my high beams are on all the time lol when I flip them to highs it gets stupid bright when I flip it to lows they dim and the halogen light comes on. Is there anyway to get the fogs to work. BTY this is on my 97 prix not the 06 thanks for the help guys
hid
