Thread: Installing Bi-Xenons help!
Results 1 to 4 of 4
  1. #1 Installing Bi-Xenons help!
    Jul 2011
    westvirginia
    installing 6000k bi-xenons very soon..Quick electronic ?'s... The DRL's..I beleive i disabled them correctly? Unplugged that clip under driverside dash, but my car also has the DRL fuse in the glovebox panel..should i remove that as well??..also, i doubt it's very good for the bulbs to flash when car is locked/unlocked..how would i disable that?..i'd LOVE to be able to hear the horn beep when i lock the car, as without the flash i'd never know if i locked the car from more than 5 feet away >.< ..01 grand prix by the way any help would be appreciated..Im sure there is some kind of procedure for the auto flash at lock, but ive yet to find the procedure -.-
  2. #2 Re: Installing Bi-Xenons help!
    Bunnell, FL
    dont pull the drl fuse
    disable the flash using your owners manual and the pgm fuse or some **** like that
    I'm a Sex Offender
  3. #3 Re: Installing Bi-Xenons help!
    Jul 2011
    westvirginia
    When i pulled the fuse it made some clicking noise under the dash, when the e brake was pressed it went away..i put the fuse back it and it stopped..but by unplugging that heatsink looking thing it will disable DRL's? because the car still has auto headlights...I just want to be sure im doing everything correctly.
  4. #4 Re: Installing Bi-Xenons help!
    GTX Level Member dbextreme's Avatar
    Nov 2009
    Tennessee
    Z3r0 is right....
    Pulling the fuse will disable everything. I think the alarm will still work but no notification at all when arming or disarming. If you like the horn honking, you'll have to go through your owners manual and find the different programs for your car.. You'll have to pull the pgm fuse, turn the key 4 times, turn on the wipers, click your heels together, smack your girlfriend in the a$$, turn the key off, then plug in the fuse for program 1.. you got like 7 more settings to go.. LOL Me, I just unplugged the fuse. Haven't had a problem and I like controling my lights with the switch instead of using the auto lights because they are on a lot due to me having my front windshield tinted, throws the sensor off...
  1. Installing MPS Hub
    By ls1camino in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-03-2011, 07:55 AM
  2. Installing new HU
    By CMURDAx in forum Audio, Security & Visual Electronics
    Last Post: 06-13-2010, 12:00 AM
  3. installing HUD
    By joshsGT in forum Audio, Security & Visual Electronics
    Last Post: 03-16-2010, 10:47 PM
  4. installing LOC
    By Preston in forum Audio, Security & Visual Electronics
    Last Post: 09-12-2008, 12:08 PM
  5. Installing HUD?
    By retski420 in forum General Tech Discussion
    Last Post: 03-17-2008, 02:29 PM
