Thread: Removing Cigarette Lighter
Results 1 to 4 of 4
  1. #1 Removing Cigarette Lighter
    SE Level Member matthew911's Avatar
    Feb 2010
    Is there any trick to removing this thing? I grabbed one out of a junkyard that's still attached to the tray. Been playing around with it for a bit, but it really doesn't want to come out of there. I was hoping to replace the defective one in my car without removing the tray, because I'm not really sure how the tray comes out.
  2. #2 Re: Removing Cigarette Lighter
    I've seen two types of light attachments. One is there are two pieces and they screw together. the other is small tabs that hold it in place.
  3. #3 Re: Removing Cigarette Lighter
    Feb 2010
    Yeah, it looks like there are small tabs, but it doesn't look like the lighter is detachable...at least without breaking something. The tabs don't push in. I've found nothing on the internet to help me with this. Apparently it's not a common thing to swap out in a Grand Prix.
  4. #4 Re: Removing Cigarette Lighter
    my regal had the twist on ring on the outside of the console holding the cig lighter up from the bottom. the whole socket would turn, so i had to hold the socket and turn the top of it, had a plastic spacer on the bottom (on the socket but under the console) too i think.
    have you tried to fix yours? get some 100 grit sand paper and clean out the inside of your old one, and some times the ground wire likes to fall off too. im sure you checked the fuse already.
  1. Cigarette Lighter 04 Grand Prix GT Please help
    By bjornbjorn in forum Off Topic Discussion
    Last Post: 07-26-2010, 01:06 AM
  2. Cigarette Lighter Fuse
    By matthew911 in forum General Tech Discussion
    Last Post: 04-06-2010, 10:35 PM
  3. brake lights, cigarette lighter, turn signal wont work
    By dlouis30 in forum General Tech Discussion
    Last Post: 03-03-2010, 10:31 AM
  4. Cigarette Lighter Problems
    By missyfisch in forum Audio, Security & Visual Electronics
    Last Post: 10-08-2009, 09:39 AM
  5. Removing ash tray/rearranging cigarette lighter?
    By Deezul_AwT in forum Visual/Body Modifications
    Last Post: 04-17-2008, 05:32 AM
