Thread: Hole in Rocker :( Need help & opinions!
Results 1 to 11 of 11
  1. #1 Hole in Rocker :( Need help & opinions!
    Cambridge, Ontario Canada
    Rockers are both sides are in rough condition but the passenger side has a hole about 4 inches by 2 through it. I need to patch this hole to get the safety & put the car on the road (want car to get me 3 more years).
    New rockers are going to cost double what I paid for the car - so they are not an option right now. I have read people using spray foam, cardboard & t-shirts lol - then bondoing over. I had done a similar repair on another vehicle once and used fiberglass (was ok).
    I was thinking the fiberglass route again but not sure how well it will adhere to rusty areas, then completely soak the rockers underneath in a roofing tar - that should visually hide the cancer, then get a full oil spray. I am thinking that might buy me the 2-3 years or more? Rest of the car is in great condition.
    Need opinions?
    Was also thinking of taking the skirts off to inspect real damage. To confirm remove bolts on each end, then pull entire assembly away from car so it can slip out of the rocker channel that supports the bottom? There might be a clip near the front? 3M tape somewhere?
    Thanks
    2005 E55 - stock
  2. #2 Re: Hole in Rocker :( Need help & opinions!
    What you want is some POR15. That stuff is paint on and stops rust in it's tracks. Then do your patch and hope that it stops there. Because the rockers on a GP rust... it's simple.
  3. #3 Re: Hole in Rocker :( Need help & opinions!
    Called up the closest POR15 dealer, he said clean, metal ready and paint is $100 for a quart sized kit. Think that will be enough?
    2005 E55 - stock
  4. #4 Re: Hole in Rocker :( Need help & opinions!
    A quart is a lot. I think it would be.
  5. #5 Re: Hole in Rocker :( Need help & opinions!
    Feb 2009
    flintnasty MI
    you would not need more than a pint.
    I could paint an entire car twice with a quart.
  6. #6 Re: Hole in Rocker :( Need help & opinions!
    Wow serious? The pint kit is much cheaper too.
    So do the POR thing, then fiberglass patching or do fiberglass patching first then POR the hella out of it too?
    2005 E55 - stock
  7. #7 Re: Hole in Rocker :( Need help & opinions!
    MA
    Really!!!
  8. #8 Re: Hole in Rocker :( Need help & opinions!
    GT Level Member TeeWX's Avatar
    Apr 2009
    Cresco, Iowa
    When I clicked on this thread I for some reason thought you were talking about the rockers in the valvetrain, and I got all excited. But its just rust.
    1998 GTP : XP Cam, 3.2 Pulley, Supporting Mods<Sold>
    2001 Formula M6 : Shhhh
    2001 SSEi : New DD, Bone Stock for now
  9. #9 Re: Hole in Rocker :( Need help & opinions!
    Florida
    You do the POR15 first, so that it's contacting the rust directly, so it can encapsulate it, and stop it from spreading, then you patch.
  10. #10 Re: Hole in Rocker :( Need help & opinions!
    Just pulled the skirts off and broke the front F-bombing clip off of the plastic skirts. Wonder if an epoxy will bond it strong enough to reattach? Also, my sideskirts had no double sided tape (at least on the passenger side). "Ladder" rails look kinda crappy but I think they'll survive.
    so what to do about broken clip? Anyone tried fixing?
    Where should double sided tape go?
    2005 E55 - stock
  11. #11 Re: Hole in Rocker :( Need help & opinions!
    GT Level Member papaspanky's Avatar
    Jul 2010
    new england
    I use rust bullet it works better than por 15 and is cheaper 30.00 for 1/2 pint and comes with everything yoiu need.oh and it is guaranteed not to rust for 10 years
    81 T/A pure Pontiac 350,700r4 3.23's coming soon pure Pontiac 462 06 gt wizaird,XS power Headers,zzp ss ic,overkill tune 180 stat autolite 104's, 3.6 pulley.Special Edition HORNY DRIVER mod.
  1. Hole prep
    By tdm571 in forum Visual/Body Modifications
    Last Post: 04-04-2011, 07:31 PM
  2. hole in VC
    By gtpinsc in forum General Tech Discussion
    Last Post: 01-23-2011, 10:50 AM
  3. Some A** HOLE egged my car
    By hanback in forum The Rant Forum
    Last Post: 11-09-2010, 11:13 AM
  4. so some a$$ hole wants to fight me...
    By mezzoni in forum The Rant Forum
    Last Post: 07-19-2010, 01:27 PM
