Thread: painting engine cover
Results 1 to 13 of 13
  1. #1 painting engine cover
    Michigan
    i have a few questions about painting my engine cover...are there any reccommendations on what type of paint to use for this do i need a high temp paint? im not sure if krylon fusion would be good for this type of application or not. does the cover need to be sanded first? should i put on a spray clear coat when im done? and lastly would i be able to put overlays on the 3800 and supercharged emblems? like would they stick...im sure these are simple questions but i just want to be sure on some of this stuff before i jump into painting my engine bay
  2. #2 Re: painting engine cover
    Omaha, NE
    I sprayed mine with Krylon Fusion, it's never on my car though.
  3. #3 Re: painting engine cover
    Michigan
    thats what i was going to use but im afraid it would crack and peel with the heat of the engine
  4. #4 Re: painting engine cover
    Painted engine cover = RIIIIIIIIIIIIIIIIIIIIIIIIICE.
    Find a guy named Whitcomb.
    Have him paint it...zomg awesome looking.
  5. #5 Re: painting engine cover
    Omaha, NE
    I'll second the excellence of whitcombs work.
  6. #6 Re: painting engine cover
    Michigan
    i dont want to spend a bunch of money on it i just wanted to do it myself if it was an easy thing to do
  7. #7 Re: painting engine cover
    Omaha, NE
    Try Fusion, it shouldn't let you down. If it does for some reason fail, get high heat engine enamel.
  8. #8 Re: painting engine cover
    Michigan
    do you think the overlays will adhere to the gloss clear coat?
  9. #9 Re: painting engine cover
    GT Level Member Jakescoots's Avatar
    Spring Lake, Mi
    Quote Originally Posted by Wingsfreak9 View Post
    They stick to the cars for forever, so....
    Does removing the spare count as weight reduction?
    Badges on a car are just advertisements....Everyone already knows what it is. And if they dont, its a mystery. People like mysteries.
  10. #10 Re: painting engine cover
    Helena, MT
    I've got fusion and it's worked great close to a year now. No flaking or anything of any kind
  11. #11 Re: painting engine cover
    Donating Users str3etgl0w's Avatar
    Jun 2011
    Saginaw Mi
    I used the high heat engine enamel on my old GT turned out good no clear coat I believe clear coat is much more flammable I am sure you could find some high heat clear coat but i dunno
    lol needs a bad cleaning
  12. #12 Re: painting engine cover
    Texas
    I need something to cover the ugliness of the vacuum lines behind the UIM. It's a freaking rats nest! Anyone done anything back there?
    85 Corvette
    01 TA
    03 Z06
  13. #13 Re: painting engine cover
    Michigan
    im goin to try gloss white fusion and see how it turns out without a clear coat I'll post up a pic when it's finished
  1. Painting engine cover
    By Taz Magister in forum Visual/Body Modifications
    Last Post: 03-06-2011, 06:44 PM
  2. Painting Engine Cover and blower
    By DBGP in forum General Tech Discussion
    Last Post: 07-27-2010, 02:33 AM
  3. new engine cover, braces n fusebox cover
    By beckys2000gt in forum Visual/Body Modifications
    Last Post: 05-27-2010, 09:40 AM
  4. Painting my engine cover
    By ItZ MiKe 718 in forum Visual/Body Modifications
    Last Post: 04-05-2009, 05:04 PM
  5. Prep for painting engine braces?
    By Deezul_AwT in forum Visual/Body Modifications
    Last Post: 06-09-2008, 02:54 PM
