Thread: This is why I've never debadged my trunk. I need some advice guys.
Results 1 to 20 of 30
  1. #1 This is why I've never debadged my trunk. I need some advice guys.
    West Side Michigan
    So.. When I got my car it had a new paint job on it. Woot right? Nope..
    They didn't remove the badges on the car.. I didn't really care because I was never going to remove the "GTP" badges.. but I did want to remove the "Grand Prix" on the trunk. I just removed them, and there is a step in the paint, and it's visible..
    What should I do?
    Can I lightly sand until the line goes away?
  2. #2 Re: This is why I've never debadged my trunk. I need some advice guys.
    Never Never Land
    Wet sand MIGHT work...might just **** it up. I'd give it a go though. The worst that can happen is your gonna have to get the trunk repainted.
  3. #3 Re: This is why I've never debadged my trunk. I need some advice guys.
    GTP Level Member sdavis11b's Avatar
    Atlanta, GA
    Hmm, you could wet-sand and buff to get the lines out but it almost looks like you can tell a difference between the factory and aftermarket paint jobs. Might just be the picture though. The wet-sand/buff would not be able to help the difference in paint, just get rid of the lines in the clear. So you would always be able to see that there was once a grand prix emblem there. Sucks man
    2004 GTP - TEP TRANS, INTERCOOLER, 3.0, AND PLENTY OF KR...
  4. #4 Re: This is why I've never debadged my trunk. I need some advice guys.
    F that.
    I got some chrome "Grand Prix" badges I'll send you to put back on from an SE that I think should have came on the GTP's since it was flashier.
    Seriously walrus...whats your addy so I can get all of those send out to you anyways.
  5. #5 Re: This is why I've never debadged my trunk. I need some advice guys.
    yeah, you need to put that badge back on, its never going to match or look right. different colors for sure.
  6. #6 Re: This is why I've never debadged my trunk. I need some advice guys.
    May 2008
    Winnipeg, MB
    X2
    2007 Pontiac Grand Prix
  7. #7 Re: This is why I've never debadged my trunk. I need some advice guys.
    Waukesha, WI
    holy hack work
    id put the emblem back on till you can afford to get it sanded down and re painted
    RayRay
    92 Turbo miata
    71 bagged lemans wagon
    02 lexus is300
  8. #8 Re: This is why I've never debadged my trunk. I need some advice guys.
    I'd try clay bar that and some heavy compound 1st. I took the ones off the trunk of my black car too and I need to wetsand mine becasue im not putting badges back on. If your careful 2000 grit wetsand and some wax would take care of it too. Make sure you add a few drops of car wash soap to the water for the sand paper too.
  9. #9 Re: This is why I've never debadged my trunk. I need some advice guys.
    Jul 2008
    Tampa, FL
    yikes, good luck man. if i were you, i'd just rock the badges...no big deal
  10. #10 Re: This is why I've never debadged my trunk. I need some advice guys.
    Omaha, NE
    First you should use some goo gone, because it looks like there's still some adhesive on there.
    After that give the area and or whole trunk a nice wax, that should take care of a good amount of it.
    From my experience with debadging a few cars, it looks like the rest of the car has sun fade, not necessarily a bad paint job. It should get to a point where it's not noticeable at all.
  11. #11 Re: This is why I've never debadged my trunk. I need some advice guys.
    GTX Level Member tayl5645's Avatar
    Jul 2010
    Michigan
    THis would make me slightly more hesitant about debadging which I have thought about
    2005 GTP Grey
    Custom built Open cone intake, 15% tints all the way around, 7" touchscreen DVD player
  12. #12 Re: This is why I've never debadged my trunk. I need some advice guys.
    West Side Michigan
    Quote Originally Posted by tayl5645 View Post
    Don't be scared. If your car has an original paint job.. you're more then fine.. this is because the guys before me didn't take the badges off before painting it, resulting in this step.
    But thanks for the advice guys. Much appreciated.
    I'm gonna try goo gone, and then take some 2000 grit to it with some water and see where that gets me..
    I don't wanna put an overlay over it or put a "GTP" badge over it because I have something custom I wanna do with the trunk that no ones done before... so I need it as unnoticeable as possible.
    Thanks again guys, I'll report back with what happens.
  13. #13 Re: This is why I've never debadged my trunk. I need some advice guys.
    Grand Island, Nebraska
    Quote Originally Posted by nawarkk View Post
    So were not gonna be twins anymore?
  14. #14 Re: This is why I've never debadged my trunk. I need some advice guys.
    West Side Michigan
    Quote Originally Posted by JoRoW99 View Post
    If I am able to get this working, I'll send you a copy of what I'm doing to the trunk if you want
  15. #15 Re: This is why I've never debadged my trunk. I need some advice guys.
    Haha sounds good. I doubt Id to it though, depending on price.
  16. #16 Re: This is why I've never debadged my trunk. I need some advice guys.
    Bunnell, FL
    do this
    I'm a Sex Offender
  17. #17 Re: This is why I've never debadged my trunk. I need some advice guys.
    The Boss Iceman6669's Avatar
    Jun 2011
    Quote Originally Posted by z3r0 View Post
    do this
    That is exactly what i want to do. I just de-badged last night. I didnt use goo-gone I used rubbing alcohol. Then I had a little paint fade and I had to do a good buff job. I just did like 3 coats of wax and some elbow grease. But now I wanna put on some GTP badges.
  18. #18 Re: This is why I've never debadged my trunk. I need some advice guys.
    You could try something else, like this
    Reflective Concepts - Get NOTICED!
    Or try the cheap methods of trying to fix it first. After that....I'd probably just put them back on. maybe a different color.
  19. #19 Re: This is why I've never debadged my trunk. I need some advice guys.
    Windsor (ON) Canada
    ^^ That for sure.. see if you can get one that matches your PONTIAC inlay... you may start a trend
  20. #20 Re: This is why I've never debadged my trunk. I need some advice guys.
    Like I said Walrus...I'm going home this weekend and I'll send them out when I'm there. Forealzies. Now that I know you actually NEED them hahaha.
    Quote Originally Posted by 98GrandPrixIraqVet View Post
    I'd try clay bar that and some heavy compound 1st. I took the ones off the trunk of my black car too.
    Vet...there is a big difference from a paint that is just weathered from having the badge covering it...to having someone paint it a totally different color. Your not getting that to match with some heavy cutting compund and wetsanding. For all you know it could be green under all of that. Then it'd be worse.
    do this
    Don't.
    Datbeugly.
    Quote Originally Posted by Colossus View Post
    How's that any different than overlayin' the badges? lol.....
  1. 05 GT debadged
    By zx7r4u2nv in forum Visual/Body Modifications
    Last Post: 03-02-2011, 05:43 PM
  2. Hey guys! new GTP owner lookin for advice and others to get together with in GA
    By Spartanzz in forum Introductions/Noob Questions
    Last Post: 01-29-2011, 07:41 AM
  3. gtp door badge in rear? or leave it debadged?
    By 2000GTP in forum Visual/Body Modifications
    Last Post: 02-19-2009, 12:18 PM
  4. hey guys need advice
    By triplecanopy in forum Off Topic Discussion
    Last Post: 12-21-2008, 11:57 PM
  5. Cleaned Up & Debadged!
    By jdbaringer in forum Off Topic Discussion
    Last Post: 03-18-2008, 08:10 PM
