Thread: Retrofit help
Results 1 to 8 of 8
  1. #1 Retrofit help
    May 2011
    Mi
    So im doing my retrofit on my 04 gp and i got off the lense but I cant seem to get off the Black housing part. how does this come off? is it glued also?
  2. #2 Re: Retrofit help
    GT Level Member jmoore4294's Avatar
    It's got tabs on it that are placed in the butly tape when the headlight is sealed. So there's probably some butyl left on those tabs that hardened back up. Heat it up just a bit more with a hair dryer or however you did it and pull. It'll come right out.
    2004 Pontiac Grand Prix GT2 -Wizaired-DHP Tune-180° Thermostat-GMPP STB w/brackets F/R-Bilstein HD Struts w/SSC-Projector Retro-Black SPO Grilles and Spoiler-ZZP Volt. Booster & Alt Rewire
  3. #3 Re: Retrofit help
    Kansas
    The reflector is held in with 3 ball/socket connections.
  4. #4 Re: Retrofit help
    Kansas
    What are you using as a projector? Mori Mini H1?
  5. #5 Re: Retrofit help
    May 2011
    Mi
    i thought that was what it is. and im using the mini H1
  6. #6 Re: Retrofit help
    Kansas
    Yeah... I am in the process of doing my retro. I broke my reflector putting it back in. But it pulls straight out from the rear black housing. Be very gentle with it as the will break easily. And have fun... its a PITA.... lots and lots of cutting/sanding.
  7. #7 Re: Retrofit help
    May 2011
    Mi
    Yeah i know hah its not the easiest thing to do hah
  8. #8 Re: Retrofit help
    May 2011
    Mi
    So how exactly do you get the projectors out? i see a small bolt inside the housing but behind the reflector. but that isnt all that needs to come off is it?
  1. 04+ Projector Retrofit
    By Koniig in forum Visual/Body Modifications
    Last Post: 07-10-2017, 03:02 PM
  2. HID\Projector Retrofit advice and tips
    By laferri2 in forum Visual/Body Modifications
    Last Post: 09-07-2011, 08:50 AM
  3. My Projector Retrofit
    By Dawings33 in forum 04+ Specifics
    Last Post: 09-06-2011, 09:49 PM
  4. Retrofit Suggestions
    By GPGT2004 in forum Visual/Body Modifications
    Last Post: 07-02-2011, 01:12 PM
  5. Projector retrofit
    By rocket69GTP in forum Visual/Body Modifications
    Last Post: 04-17-2011, 12:46 PM
