Thread: HID\Projector Retrofit advice and tips
Results 1 to 20 of 59
  1. #1 Re: HID\Projector Retrofit advice and tips
    GT Level Member jmoore4294's Avatar
    Quote Originally Posted by laferri2 View Post
    16. Wet sand and buff front and back of lenses
    Don't touch the inside of the lens. Even with a paper towel or microfiber. You will scratch the sh!t out of it. You'll only need to wetsand/buff the outside of the lens. Also, make sure you test fit them on the car BEFORE you seal up the headlights. You need to make sure the rotational adjustment is correct before you seal them up as the headlights on our cars sit at an angle.
    Also, I don't know if this is a problem with the aftermarket 'OEM' headlights for our cars or if it's for original OEM headlights too, but when you adjust them down with the projector in, you might notice that the projector will rotate counter-clockwise. And when you adjust them up, they will rotate clockwise. So you may need to compensate for that.
    2004 Pontiac Grand Prix GT2 -Wizaired-DHP Tune-180° Thermostat-GMPP STB w/brackets F/R-Bilstein HD Struts w/SSC-Projector Retro-Black SPO Grilles and Spoiler-ZZP Volt. Booster & Alt Rewire
  2. #2 Re: HID\Projector Retrofit advice and tips
    May 2011
    MI
    How do you aim projectors other than with the built in level?
  1. 04+ Projector Retrofit
    By Koniig in forum Visual/Body Modifications
    Last Post: 07-10-2017, 03:02 PM
  2. HID Projector Retrofit
    By DanGTP in forum General Tech Discussion
    Last Post: 10-04-2011, 02:15 PM
  3. My Projector Retrofit
    By Dawings33 in forum 04+ Specifics
    Last Post: 09-06-2011, 09:49 PM
  4. Projector retrofit
    By rocket69GTP in forum Visual/Body Modifications
    Last Post: 04-17-2011, 12:46 PM
  5. Projector retrofit for 9006 04+ from 3B?
    By Ashman in forum Visual/Body Modifications
    Last Post: 01-03-2010, 12:11 AM
