Use H1's proven fact they fit if you drill the hole. D2S are bigger from top to bottom anyways. It's a lot easier than trying to fit an oversized projector in.
Unless you already have the hid kit bought and you purchased amp to D2S connector so your D2S bulbs will work. I wouldn't say D2S projectors are any different really other than bulb. If you plan to put cheap bulbs in D2S it's a waste. If you're installing some Phillips D2S then it might be worth it I dunno.
