Thread: Two Morimoto projectors one cup...uh...I mean headlight...headlight
Results 1 to 20 of 240
  1. #1 Re: Two Morimoto projectors one cup...uh...I mean headlight...headlight
    Thats a better job than I did...I broke my plastic behind the light, but I repaired it.
    If I could do it over again, I would do it like yours, that bottom rubber grommet is important to keep the lights from shaking, but I found another solution to stopping the shake too...In fact...that reminds me, I need to find the other piece to help stop the headlight shake.
  2. #2 Re: Two Morimoto projectors one cup...uh...I mean headlight...headlight
    GT Level Member RedDawnGXP's Avatar
    Indiana
    Quote Originally Posted by DrunkietheBear View Post
    Drunkie, is your car an '04? If so, isn't there a different mounting tab or bracket than 05+ models? I know I've seen somewhere on these forums that there are headlight "bounce-fix" kits available from (GM?), (aftermarket?).
  3. #3 Re: Two Morimoto projectors one cup...uh...I mean headlight...headlight
    Quote Originally Posted by RedDawnGXP View Post
    Yeah 04s had the plastic clips, I bought the metal clips a long time ago, but I cut the rubber grommet out thats in the bottom left corner. That helps to stop bounce...My bad. I figured out another solution to stop the bounce though
  4. #4 Re: Two Morimoto projectors one cup...uh...I mean headlight...headlight
    Indiana
    I'm not surprised. One thing I've learned about you is that you are pretty resourceful.
  1. DRL headlight help..
    By singularity in forum Audio, Security & Visual Electronics
    Last Post: 09-02-2009, 02:29 AM
  2. Headlight
    By gptrell502 in forum Visual/Body Modifications
    Last Post: 03-20-2009, 09:49 PM
