It is basically all plug and play. When you get everything in front of you, you'll understand how it works.
The relay just needs a positive (your battery) and a negative (a ground). Then you just connect it to your HID kit. The HID kit will only need to plug in where your original bulbs used to plug in.
Pretty simple, if you need help you can always come on here
