Thread: HID Replacement Bulb???
Results 1 to 6 of 6
  1. #1 HID Replacement Bulb???
    GTX Level Member nikkigpgt00's Avatar
    MI
    I need a new HID bulb I was wondering if it matters if I get it from the same place I got my kit from? I bought the kit on ebay and don't remember the seller. I know I need a 9007 10,000K bulb but is there a difference in wattage at all? I want to make sure it looks the same as the other one. I have never replaced my HID bulb so I am not sure what to look for???
    Also, does anyone know how to remove the fog lights? I want to tint them...
  2. #2 Re: HID Replacement Bulb???
    Ocala, FL
    Any hid bulb will be fine, just be sure it's the correct size, and temperature you want.
    Best thing I can say for removing the fog light is jack it up and get under there, you'll figure it out.
  3. #3 Re: HID Replacement Bulb???
    GTX Level Member Warhellride's Avatar
    Norfolk, VA; originally from NH
    I recommend replacing both bulbs. Bulbs from different manufacturers, or even different batches from the same manufacturer, can have slightly different colors. Also, HID bulbs colorshift (become bluer and lose output) over time, so the chances of a new bulb matching your old bulb are pretty slim.
    To remove the fog lights: There are two 10mm nuts behind the foglights located on each side towards the top of the foglight (about 10 and 2 on a clock). You'll need to remove a plastic tip from the bolt first, and use a deep socket. They're pretty easy to find by feel once you know what to look for.
    2004 Mercedes-Benz CL55 AMG
    2002 Redfire Metallic Grand Prix GT Coupe (sold after 141,754 miles)
  4. #4 Re: HID Replacement Bulb???
    MI
    Is it possible to get new bulbs that work as high and low beam or is that dependent on the kit I have?
  5. #5 Re: HID Replacement Bulb???
    GT Level Member stevenk8's Avatar
    Macomb MI
    Where in michigan are you? i got a set of 9007 10k bulbs id sell yea, pm me.
    2002 grand prix gt (CAI,180*tstat,MSD wires,magnaflow high flow cat,ubend delete,18in wheels,HID headlights and fog lights)
    More mods soon to come!
  6. #6 Re: HID Replacement Bulb???
    Nov 2009
    Grand haven
    Make sure you check your ballast. Unplug the GOOD bulb and plung in the BAD bulb to check if it is the ballast. I have had the same problem and it was the ballast NOT the bulb.
  1. Foglight bulb replacement
    By kenneth74gt in forum General Tech Discussion
    Last Post: 07-25-2010, 10:51 PM
  2. Fog lamp bulb replacement question
    By Frank217 in forum Visual/Body Modifications
    Last Post: 06-21-2010, 05:04 PM
  3. horizontal or vertical bulb replacement
    By raymondtrudeau in forum General Tech Discussion
    Last Post: 10-14-2009, 08:55 PM
  4. how to guide for dash bulb replacement?
    By mrb in forum Visual/Body Modifications
    Last Post: 03-02-2009, 01:11 AM
  5. Fog Lamp Bulb Replacement
    By GPSims39 in forum General Tech Discussion
    Last Post: 11-29-2008, 07:16 PM
