Thread: center brake light
Results 1 to 7 of 7
  1. #1 center brake light
    Oregon
    how do you remove the center brake light housing? i need to clean and paint it
  2. #2 Re: center brake light
    West Side Michigan
    If this is for a 97-03, you have to remove your seats, remove the rear deck, remove all the insulation, and then you can pull the center brake light housing backwards to slide it out of the locks and then pick it up..
    Yes.. it's that hard to get to that housing.
  3. #3 Re: center brake light
    Willoughby, Ohio
    remove lower seat by pulling 2 tabs under the cushion in the front
    remove seat belt connectors
    remove the 2 bolts securing the upper seatback and lift seatback off
    remove c-pillar interior trim, just held in by clips (watch out for defrosters)
    slide rear deck out and there ya go!
    sounds easy right?
  4. #4 Re: center brake light
    Oregon
    DAMN what a PIA thanks for the help
  5. #5 Re: center brake light
    Willoughby, Ohio
    you change change your rear speakers if you like while your at it
  6. #6 Re: center brake light
    Nov 2008
    Waterloo, Iowa
    It has a few steps, but it doesn't honestly sound that hard...
  7. #7 Re: center brake light
    MA
    Maybe this will help you..
  1. Water in LR brake light housing/ABS light
    By andante147 in forum General Tech Discussion
    Last Post: 05-31-2010, 08:01 PM
  2. e-brake light
    By PNIGZ in forum Brakes/Suspension/Chassis
    Last Post: 02-26-2010, 06:12 PM
  3. my 4th brake light and 3rd reverse light
    By HART in forum Visual/Body Modifications
    Last Post: 11-05-2009, 01:33 PM
  4. Third Brake Light & LED's
    By Metallistar in forum Audio, Security & Visual Electronics
    Last Post: 05-29-2009, 11:06 PM
  5. Message Center light is out
    By aspivek in forum General Tech Discussion
    Last Post: 05-04-2009, 04:44 PM
