Thread: Rear inner trunk rusting where the struts connect!
Results 1 to 13 of 13
  1. #1 Rear inner trunk rusting where the struts connect!
    SE Level Member PTGsDaytona500GTP's Avatar
    Jul 2010
    Broadview Hts Ohio
    If I pull back the carpeting in my trunk u can see that the wheel well is rusting bad and my strut is pushing up through my trunk. I need to find that body part where can I get that. It's inside my trunk and i don't want my struts ripping through the rust and into my trunk. I have no idea where I can get this body part? Thx for reading
  2. #2 Re: Rear inner trunk rusting where the struts connect!
    Jul 2010
    Broadview Hts Ohio
    Problem solved
  3. #3 Re: Rear inner trunk rusting where the struts connect!
    Commerce Twp., MI
    I would like to know also
  4. #4 Re: Rear inner trunk rusting where the struts connect!
    Jul 2010
    Broadview Hts Ohio
    Down in cleveland there is a building where they scrap w bodys. i went there and told them i needed the rear strut mounts so they cut out those pieces of a rust free grand prix and i had a body shop weld them in
  5. #5 Re: Rear inner trunk rusting where the struts connect!
    Waukesha, WI
    i use 1/4in thick plate when i repair the towers at work
    RayRay
    92 Turbo miata
    71 bagged lemans wagon
    02 lexus is300
  6. #6 Re: Rear inner trunk rusting where the struts connect!
    Commerce Twp., MI
    how much that run you?
    and do you have a name or number for that place in Cleveland?
  7. #7 Re: Rear inner trunk rusting where the struts connect!
    SE Level Member mkedwards's Avatar
    minnesota
    definitely interested in prices
  8. #8 Re: Rear inner trunk rusting where the struts connect!
    Jul 2010
    Broadview Hts Ohio
    body pieces were 100 a piece. fyi you have to pick them up yourself so get a truck. here you go guys Morad Parts Company - 3800 Motors, Transaxles, & Stock Parts hope that helps. you should be able to find anything there.
  9. #9 Re: Rear inner trunk rusting where the struts connect!
    Donating Users Durk Diggler's Avatar
    Pittsburgh
    Thats how my Monte died. Except you could reach into the trunk by sticking your hand up under the wheel.
    Durkz 04 Silver GT2
    DHP'd, Comp G'd, looking for more speed
    http://www.grandprixforums.net/zzps-new-website-2-53834.html#post678234
  10. #10 Re: Rear inner trunk rusting where the struts connect!
    GT Level Member Euro's Avatar
    Roselle, IL
    That's exactly why I just sold my 2000 GT, although it was more worth it to me to get rid of it than fix haha. Glad you got it solved though!
    2000 Regal GS - 190k - Black over Storm Gray Metallic - 9" K&N/AL104's/Borla/GP polished tq stars/turd
    2009 Impala LT - 62k - Car Seat Mobile
    2000 Grand Prix GT - 96k - Sold/RIP
  11. #11 Re: Rear inner trunk rusting where the struts connect!
    minnesota
    im glad theres hope! how much was labor on installation? any rear alignment issues after?
  12. #12 Re: Rear inner trunk rusting where the struts connect!
    Jul 2010
    Broadview Hts Ohio
    No rear alignment issues. labor was a 1000 total.
  13. #13 Re: Rear inner trunk rusting where the struts connect!
    minnesota
    being a minnesota car that sees a lot of salt my gt has the same problem, what did you to fix it?
  1. rusting?
    By Poil336 in forum Visual/Body Modifications
    Last Post: 08-29-2009, 07:11 PM
  2. How to add adjustment to worn rear struts
    By fuzzydog1 in forum Brakes/Suspension/Chassis
    Last Post: 07-03-2009, 05:41 PM
  3. Need new Rear Struts
    By NewImage in forum Brakes/Suspension/Chassis
    Last Post: 05-06-2009, 11:12 AM
