Thread: How To Fix Fender/Door??
Results 1 to 8 of 8
  1. #1 How To Fix Fender/Door??
    Grand Rapids, MI
    Heyy. As some of you may know, my 99 Grand Prix GT was wrecked before I got it. As a long story short, the owner's kid ran it over a street sign of some sort. Anyways, in the process he did some damage. He scratched the hell out of the bumper so I just want another bumper cover. Under the car theres a bent piece but it's not affecting anything. But the fender/door is rather messed up. I can't open the passenger door without it popping really loud and I don't want to break it further. Here are some pics I took of it:
    My dad says he can fix it. So, my question is: What is the best way to do this? Does the door need to be removed? Can we just bow it out and bolt it back up? What about the way that lower door panel strip (idk the name) is bowed out?
    All help is greatly appreciated y'all. Thanks!!
  2. #2 Re: How To Fix Fender/Door??
    fender should be an easy fix! i wouldn't **** w/ the door! i'd have a dent guy do that.
  3. #3 Re: How To Fix Fender/Door??
    Grand Rapids, MI
    yea thats sorta what crossed my mind, fender would be easier i knew. why wouldnt u mess with the door tho? just out of curiosity..
  4. #4 Re: How To Fix Fender/Door??
    a dent like that, would probably crease or crack your paint if not done right.
  5. #5 Re: How To Fix Fender/Door??
    Grand Rapids, MI
    what dent are you seeing? the lower part of the door panel thing is basically just pulled out a little, from what i can tell. no real dent that i can see. just everything out of place pretty much.
  6. #6 Re: How To Fix Fender/Door??
    London Ont, Canada
    take the fender off, see if you still have the problem, door looks fine, just lighting causing it to looked caved in.
  7. #7 Re: How To Fix Fender/Door??
    Nov 2008
    Waterloo, Iowa
    I think the door problem isn't from the kid hitting something. Both my doors did this, and mine is also a coupe. The hinges get bent or shift and that causes the door to collide with the fender. Readjust the door. If it's still pretty good, you should be able to just open the door and grab it near the fender and then pull it towards the back of the car.
  8. #8 Re: How To Fix Fender/Door??
    Grand Rapids, MI
    Hm. Definite possibility... I will work on this.
  1. Door catches on fender and wont open...
    By m0ng00se in forum General Tech Discussion
    Last Post: 04-20-2010, 01:49 PM
  2. Left front fender - door question
    By VGPGT in forum General Tech Discussion
    Last Post: 06-11-2009, 05:10 PM
  3. door locks/BCM/speaker/ door question
    By adamlesandrini in forum Audio, Security & Visual Electronics
    Last Post: 03-17-2009, 05:14 PM
