Thread: 04+ removing headlight lens from assembly
Results 1 to 4 of 4
  1. #1 04+ removing headlight lens from assembly
    SE Level Member Piggy's Avatar
    Cincinnati, Ohio
    ok so there are about 100 right ups on how to restore the headlights or how to paint the inside of the headlights... either way i have to restore the inside of the lens... every how-to write up seems to be about 97-03 or later... Because i have tried every method that is on the write ups and no success whatsoever... it seems that there is clips along with the silicon and everything and its about impossible
  2. #2 Re: 04+ removing headlight lens from assembly
    Cincinnati, Ohio
  3. #3 Re: 04+ removing headlight lens from assembly
    SE Level Member neyel8r's Avatar
    DFW TX
    i knew i had previously seen that somewhere, but couldn't find it. good job
    i'm gonna need to do this soon to restore the plastic inside; seems like the passenger side headlight had gotten too hot at one point & it's become a bit foggy on top. i know it's something most people wouldn't notice unless they were looking for it, but little **** like that bugs the hell outta me...
    '05 GT - open cone intake, 80w xenons, ceramic harnesses, LED front signals\interiors\reverse lights, tint & stereo soon, the rest stock... for now
  4. #4 Re: 04+ removing headlight lens from assembly
    GT Level Member scoobyydooooooo's Avatar
    Houston, Texas
    I have did this when i painted mine,, just heat the over to 245 and leave light in there for 12-15mins,, a dremmel is a great tool to use when doing this also,, just pull pretty hard and it will separate..
    05 GTP, Inferno Appearance package, SD Headers, 2.9 Pulley, 104 autolites, Wizaired CAI, 180* T-stat, SPO tips, Nav sytem, polymounts, S2IC, XPCAM, much more to come
  1. headlight lens plastic or glass?
    By Joe m in forum General Tech Discussion
    Last Post: 01-29-2010, 06:58 PM
  2. headlight lens
    By david hagaman in forum General Tech Discussion
    Last Post: 04-13-2009, 02:17 PM
  3. headlight lens and housing
    By TDCRacing in forum Shops and Community Heroes
    Last Post: 08-30-2008, 01:14 PM
