Thread: Let there be LIGHT! (Morimoto projector retrofit)
Page 2 of 2 FirstFirst 12
Results 21 to 40 of 40
  1. #21 Re: Let there be LIGHT! (Morimoto projector retrofit)
    SE Level Member Slueth66's Avatar
    Nov 2008
    Iowa
    I'm running the 35 watt. One of these is plenty bright to drive with at night. It took me a lot of time to get them to my perfectionist standard but Well worth my time.
  2. #22 Re: Let there be LIGHT! (Morimoto projector retrofit)
    Nov 2008
    Waterloo, Iowa
    You can't link to your mail. Host the pictures on a site like imgur or photobucket.
  3. #23 Re: Let there be LIGHT! (Morimoto projector retrofit)
    Nov 2008
    Iowa
    my bad guys, ill repost after work today.
  4. #24 Re: Let there be LIGHT! (Morimoto projector retrofit)
    New York
    how long did it take you to mod the stock housings? you said it was around $150 for the parts right?
  5. #25 Re: Let there be LIGHT! (Morimoto projector retrofit)
    Nov 2008
    Iowa
    I believe it was around that if you already got hids. I got the projectors and harness for 150. Mod time varies, it took me several hours and days to get these finished but I ran into some problems. I can try to help with any questions you got.
    Low beam
    Mobile Photobucket
    High beam
    Mobile Photobucket
  6. #26 Re: Let there be LIGHT! (Morimoto projector retrofit)
    Nov 2008
    Waterloo, Iowa
    Mobile URLs, yuck.
    Here, I'll put your full-size pics up.
  7. #27 Re: Let there be LIGHT! (Morimoto projector retrofit)
    Nov 2008
    Iowa
    thanks, I wanted to but wasn't sure how. So if you could inform me that be awesome
  8. #28 Re: Let there be LIGHT! (Morimoto projector retrofit)
    Arizona
    If you are planning on doing on this and you have oem replacement headlight get ready for a real trip getting the lens off, the sealant used on mine was like rubber cement. it took five hours for 2 people to paint the inside of mine.
    im not sure if its only the brand i have, but beware...
    my brand is TYC btw
    '00 GT- nothing special
  9. #29 Re: Let there be LIGHT! (Morimoto projector retrofit)
    Banned
    Mansfield, Ohio
    Quote Originally Posted by coreygnar View Post
    my brand is TYC btw
    That's why you put them in the oven at 150 degrees for about 7-8 minutes and pull the lense right off!
  10. #30 Re: Let there be LIGHT! (Morimoto projector retrofit)
    Arizona
    Quote Originally Posted by cleangtp View Post
    i know....
    any more heat would melt the housing, what im sying is that the glue used on oem replacement ones is different.
    my one gm original light was a breeze. the oem one was a *****
  11. #31 Re: Let there be LIGHT! (Morimoto projector retrofit)
    GTX Level Member Confusingboat's Avatar
    Minnesota
    I put my OEMs (stockers) in the oven at 230*. Still took ****ing forever to get them apart. Seriously that black sealant is a *****, I'm thinking about getting rid of it altogether to make headlight modding easier on myself.
    2004 Grand Prix GT2 - SOLD
    2015 Evo MR
  12. #32 Re: Let there be LIGHT! (Morimoto projector retrofit)
    Banned
    Mansfield, Ohio
    I can do these retrofits for people no problem!
  13. #33 Re: Let there be LIGHT! (Morimoto projector retrofit)
    GT Level Member Tommyp2010's Avatar
    Poland, Ohio
    My oem replacent lights were Horrible to get apart. I had to put them in at 275 for ten minutes to get the adhesive to soften at all. The housing took that heat fine. I'm working on doing this retrofit now. I hit a few snags but the way I'm mounting them should look much more oem than the way it's done here, and I won't have to adjust to remove the cross beam. I'm just waiting for either a warm day, or to finally get my garage heated finally, plus a day off work for once. I'll post up a how to of how I did it and my results when im done.
    2006 Mitsubishi Evo IX MR
  14. #34 Re: Let there be LIGHT! (Morimoto projector retrofit)
    Nov 2008
    Iowa
    yea beam cross is a pain, im interested to see how your going to mount them.
  15. #35 Re: Let there be LIGHT! (Morimoto projector retrofit)
    SE Level Member K Dawg ONE's Avatar
    Dec 2010
    Windsor, Ontario, Canada
    So, if I already have a hi/lo 9007 kit, i can just buy a set of hi/lo h1 bulbs right? Or can I use a the 9007 in the Mori housing?
    Kris Creed | 'GM-Pro Certified' Sales Consultant | GUS REVENBERG CHEVROLET-BUICK-GMC | Windsor, Ontario, Canada | 800-291-1117 ext. 177
  16. #36 Re: Let there be LIGHT! (Morimoto projector retrofit)
    Poland, Ohio
    Quote Originally Posted by K Dawg ONE View Post
    No, if you're retrofitting, you only need a single xenon bulb. Projectors have a cutoff shield which moves to allow more light to shine for a high beam. the high beam kicks on from the wiring harness.
    Op, how did you fit the mini gatlings? When I tried to fit mine, they didn't even come close to fitting. I had to cut them down and in the end they just ended up breaking because I cut too much off. Gonna use trimmed down e46 shrouds when it warms up and I get around to doing this.
    has anyone found where I can get actual GM replacement lights? Since they will be much higher quality than aftermarket and easier to work with.
    Edit: Ok I found genuine replacements on PFYC, but holy sh!t! They're $124 per side.
  17. #37 Re: Let there be LIGHT! (Morimoto projector retrofit)
    Minnesota
    They'll actually be harder to work with btw, just sayin. Get some aftermarket replacements.
    2015 Evo MR
  18. #38 Re: Let there be LIGHT! (Morimoto projector retrofit)
    Never Never Land
    do you have pix of these lighting up the road? Also you said they have H1 bulbs, how do you have hi beams? arent the h1's low beams? Pix of hi and lows would be greatly appreciated. My high beams just straight up suck with my spyders.
  19. #39 Re: Let there be LIGHT! (Morimoto projector retrofit)
    Banned
    Mansfield, Ohio
    Quote Originally Posted by 4THGENCAMAROFAN View Post
    Bi-xenon uses H1 when you click brights on that shield on top of solenoid drops to change beam pattern
  20. #40 Re: Let there be LIGHT! (Morimoto projector retrofit)
    Bastard Reptile's Avatar
    Kansas City, MO
    If you're serious.....I'm interested. No Joke.
  1. HID Projector Retrofit
    By DanGTP in forum General Tech Discussion
    Last Post: 10-04-2011, 02:15 PM
  2. Replies: 16
    Last Post: 01-23-2010, 09:43 AM
  3. Projector retrofit for 9006 04+ from 3B?
    By Ashman in forum Visual/Body Modifications
    Last Post: 01-03-2010, 12:11 AM
  4. Projector retrofit for 9006 04+ from 3B?
    Last Post: 01-02-2010, 11:02 PM
  5. ABS Light + Check Tire Press. Light Problems
    By element55 in forum Brakes/Suspension/Chassis
    Last Post: 01-30-2009, 02:34 PM
