Thread: Fog lights question?
Results 1 to 14 of 14
  1. #1 Fog lights question?
    south florida
    Quick question, haven't even looked at ALL. But anyways, the fog lamp light doesn't turn on when I flip the switch on the interior.
    What might be the first thing to look at. A fuse? Cut wire?..etc. Bulbs look perfect but that may be the issue too. Thanks guys!
  2. #2 Re: Fog lights question?
    Charles City, IA
    Do you have power at the socket?
    SMGPFC Two Nipple General
  3. #3 Re: Fog lights question?
    is the bulb any good?
  4. #4 Re: Fog lights question?
    south florida
    well im going to check that tomrw but if the bulbs were shot would the indicator light on the inside still light up? Because mine doesn't
  5. #5 Re: Fog lights question?
    no idea, check the fuse as well.
  6. #6 Re: Fog lights question?
    London Ont, Canada
    1 million % of the time its the bulb
    just replace it or get a new switch.. the bulb is soldered in so its not a plug and play swap, ive got about 4 switches here at home, all but 1 doesnt light up orange lol
  7. #7 Re: Fog lights question?
    Florida
    Yeah, one of my bulbs went out, and when it did, the indicator light went out, and hasnt worked since, even after replacing the bulb in the fog light, and checking for power in the switch, no big deal though.
  8. #8 Re: Fog lights question?
    GT Level Member Pkorn's Avatar
    Merrillan, Wisconsin, United States
    yea check the fuse, mine isn't turning on either but it doesnt' bother me
  9. #9 Re: Fog lights question?
    south florida
    so even with the indicator light not working the fogs still lit up when u flipped the switch?
  10. #10 Re: Fog lights question?
    Florida
    yep, and they still do.
  11. #11 Re: Fog lights question?
    London Ont, Canada
    yeah, i replaced my fogs with silverstars, and they work when you flick the switch, but up until recently the orange indicator light never came on despite the fogs working.
  12. #12 Re: Fog lights question?
    so i have 55 W H3's in my fogs with factory wiring and they work, I use them instead of running lights sometimes. Other times i just run my parking lights.
  13. #13 Re: Fog lights question?
    south florida
    ok so I guess first thing check if it's getting power, if not then check fuse. If not then jus change the bulbssss
  14. #14 Re: Fog lights question?
    Florida
    check the fuse first, its the easiest
  1. Head lights and dash lights randomly shut off
    By TheOtherNick in forum General Tech Discussion
    Last Post: 04-01-2020, 05:45 AM
  2. Replies: 0
    Last Post: 03-07-2010, 09:14 PM
  3. FWI(fender well intake) question. Exhaust(cat) question.
    By DJspinner in forum General Tech Discussion
    Last Post: 01-23-2010, 01:47 AM
  4. Replies: 3
    Last Post: 01-16-2010, 07:19 PM
  5. dim lights not working, bright lights ok
    By madmex2k in forum General Tech Discussion
    Last Post: 12-07-2009, 11:27 PM
