Thread: HID high beam question.
Results 1 to 4 of 4
  1. #1 HID high beam question.
    Apr 2008
    Ok, I've been trying to search, but the combination of words required turns up everything that doesn't help and most of the words I want are too short to actually search for, so that's why I'm having to post a new thread.
    I've got an '01 GP, with a basic 9007-1 HID set, plug and play. That means I get low beams only, and if I switch to high beams the headlights go dark. What I want to do is route power from the high beams to the low beams, so that if I accidentally hit or go into high beam mode, power stays going to the low beams and I still have light. Can this be done by just splicing (for lack of a better word) the high beam wire into the low beam wire where the HID ballast plugs into the factory bulb adapter?
    It seems straightforward enough to work, but I'm sure there are complications like voltage and amperage that I'm not accounting for, and I want to make sure it's safe to do it before I just try it. I'm pretty sure I've seen something like this asked and answered before while I was doing my research on HIDs, but for the life of me I cannot find it again.
    Anyone know how to help?
  2. #2 Re: HID high beam question.
    GT Level Member BackInBlack's Avatar
    Vermont
    There is a simple wiring mod under the dash that takes care of that problem. Be aware, that if you switch back to halogens, you MUST remove the wiring mod or damage will result.
    1) Unplug the DRL diode from the harness.
    2) Make a jumper that taps into the TAN wire on the DRL harness.
    3) Tap the jumper into the YELLOW wire at the headlamp switch, pin L.
    4) Tape up the end of the DRL harness so it won't start a forest fire...
    The GPs are long gone...
  3. #3 Re: HID high beam question.
    Apr 2008
    Oh good, more working with wires through a tiny hole with my big hands.
    Thanks for the answer, now I just have to think about the best way to get under there again.
  4. #4 Re: HID high beam question.
    Vermont
    Drop the lower IP cover and work from the bottom up... Or, you can pull the harness through the opening on the LH side of the dash and easily work right there.
  1. Question
    By Tyler_06 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-23-2008, 10:20 PM
  2. I'm looking for high resolution grand prix pictures
    By AlmightyBirdman in forum Off Topic Discussion
    Last Post: 02-21-2008, 08:56 AM
  3. HID Kits -- dual beam or retractable?
    By Toasty in forum General Tech Discussion
    Last Post: 01-20-2008, 02:00 PM
  4. high mileage trans issues
    By 01whitegtp in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-11-2008, 08:23 AM
  5. profanty filter set to high
    By chrisgtp in forum Forum Bugs/Suggestions
    Last Post: 12-29-2007, 12:11 AM
