Thread: Xenon Single Beam 35W HID Conversion Kit NOT WORKIN!!!
Results 1 to 3 of 3
  1. #1 Xenon Single Beam 35W HID Conversion Kit NOT WORKIN!!!
    GT Level Member lilbear6889's Avatar
    Hey guys wondering if anyone knew anything about Xenon Single Beam 35W HID Conversion Kit..? I ordered one from ebay just got it in n tried to install it and of course it doesnt work! tried both Ballasts in both headlights still nothing...if anyone knows any tricks or anything that maybe i could try to make it work that would be awesome! Thanks in advance [IMG]file:///C:/Users/Shannon/AppData/Local/Temp/moz-screenshot.png[/IMG]
  2. #2 Re: Xenon Single Beam 35W HID Conversion Kit NOT WORKIN!!!
    Donating Users Warbeaver's Avatar
    St. Louis
    are you using a relay harness?
    and second, there is a trick called reversing polarity. Take the plug that plugs into each ballast, and turn the connector 1/2 turn (flip it basically) then plug back in the ballast. try that and see if it works.
  3. #3 Re: Xenon Single Beam 35W HID Conversion Kit NOT WORKIN!!!
    No harness just using what the kit came with...and i will try doing that tomorrow...Thank u hopefully it works...if not im going to take it into a shop on monday and see if they can figure it out..
  1. Need High Beam, Low Beam, Fog wiring help...
    By TuKoolGTP in forum General Tech Discussion
    Last Post: 12-29-2009, 12:57 PM
  2. Xenon HID bulbs
    By Blacknight02GT in forum Off Topic Discussion
    Last Post: 06-29-2009, 05:09 PM
  3. Boost Not Workin!!!!PLZ HELP!!!!
    By LaCabra in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-06-2009, 10:23 PM
  4. New HIDs installed and High Beam/Low Beam issue CORRECTED!!! Woot!
    By GeddyLee in forum General Tech Discussion
    Last Post: 01-29-2009, 07:26 PM
  5. Xenon HID Lights?
    By bizzy187 in forum Visual/Body Modifications
    Last Post: 05-11-2008, 01:22 PM
