Thread: DIC's are for babies (new installed pics)
Results 1 to 20 of 27
BoostJunki3 DIC's are for babies (new... 04-08-2010, 06:54 PM
CTKGP09 Re: DIC's are for babies :) 04-08-2010, 06:59 PM
BoostJunki3 Re: DIC's are for babies :) 04-08-2010, 07:13 PM
minichopper6hp Re: DIC's are for babies :) 04-08-2010, 06:59 PM
BoostJunki3 Re: DIC's are for babies :) 04-08-2010, 07:11 PM
CTKGP09 Re: DIC's are for babies :) 04-08-2010, 07:14 PM
nawarkk Re: DIC's are for babies :) 04-08-2010, 07:14 PM
BoostJunki3 Re: DIC's are for babies :) 04-08-2010, 07:18 PM
nawarkk Re: DIC's are for babies :) 04-08-2010, 07:20 PM
minichopper6hp Re: DIC's are for babies :) 04-08-2010, 07:24 PM
BoostJunki3 Re: DIC's are for babies :) 04-08-2010, 07:39 PM
speedemongtp Re: DIC's are for babies :) 04-08-2010, 07:25 PM
CTKGP09 Re: DIC's are for babies :) 04-08-2010, 07:26 PM
BoostJunki3 Re: DIC's are for babies :) 04-08-2010, 07:40 PM
CTKGP09 Re: DIC's are for babies :) 04-08-2010, 07:42 PM
BoostJunki3 Re: DIC's are for babies :) 04-08-2010, 07:44 PM
CTKGP09 Re: DIC's are for babies :) 04-08-2010, 07:46 PM
minichopper6hp Re: DIC's are for babies :) 04-08-2010, 07:56 PM
Mad Monkey Re: DIC's are for babies :) 04-08-2010, 10:34 PM
BoostJunki3 Re: DIC's are for babies :) 04-09-2010, 12:32 AM
cerick08GP Re: DIC's are for babies (new... 04-09-2010, 01:05 AM
TorqueAutoMotiv Re: DIC's are for babies (new... 04-10-2010, 11:43 AM
BoostJunki3 Re: DIC's are for babies (new... 04-10-2010, 02:40 AM
SilvaMan61 Re: DIC's are for babies (new... 04-10-2010, 10:39 AM
Mad Monkey Re: DIC's are for babies (new... 04-10-2010, 11:56 AM
SeanGTP Re: DIC's are for babies (new... 04-10-2010, 04:38 PM
Mad Monkey Re: DIC's are for babies (new... 04-10-2010, 09:39 PM
  1. #1 DIC's are for babies (new installed pics)
    Joliet, IL
    finally got the supplies and time to finish a long awaited project
    supplies:
    (3) 90* 2" pvc bends smaller end opening is exactly 52mm opening, cut off that end.
    (1) can bondo body filler, hardener, spot putty
    (1) tube of plastic epoxy gel
    (1) 60 grit coarse sanding sponge, 100 grit smoothing sponge and 320 grit primer prep sponge and 60 grit coarse sheets of sand paper.
    (1) can of filling primer, truck bed coating (truck bed by duplicolor has a slight dimple just like the stock texture and near color match of the dash and its flat black/charcoal to hide imperfections..)
    first i put screws through the dash in places to hold the cut pvc rings exactly where i wanted them, then epoxied them in place and removed screws when dry. next i used duct tape to make a back plate behind the gauge cups and to close off the back of the dash's dic hole, this lets the bondo fill against something. next i mixed small amounts of bondo body filler (directions on can) and filled in the gaps and holes in excess (dont worry about using alot and making it look sloppy this will be fixed with sanding), let dry for 30 mins....take 60 grit sheets and begin removing all bumps and shaping all the bondo to a good looking shape and once you have it there take your 60 grit sanding sponge and smooth and shape further (this is along process so take your time making it perfect!) next smooth it make it a level surface with 100 grit sponge and further smooth it next with the 320 grit sponge. finally clean it free of dust. (you can use the spot putty to fill dimples or minor imperfection and LIGHTLY sand with 320 grit) next lay some primer on it let it dry sand smooth and finally lay the truck bed coating on here is the results...
    now i just need a wideband!
    SD slot on comp is messed up so sorry cell pics are all i got looks alot better in person with no blur
    00 Silvermist GTP
    13.2 @ 104. No Cam No IC.
  2. #2 Re: DIC's are for babies :)
    Willoughby, Ohio
    looks good, nice work but i just got my digital DIC and im noo baby!
  3. #3 Re: DIC's are for babies :)
    Joliet, IL
    Quote Originally Posted by CTKGP09 View Post
    00 Silvermist GTP
  4. #4 Re: DIC's are for babies :)
    Banned - Busted For Scamming
    Feb 2009
    Nice but why didnt you glass it instead?
  5. #5 Re: DIC's are for babies :)
    Joliet, IL
    had filler chillin in the garage lol im cheap and it looks just as good for cheaper!
    00 Silvermist GTP
  6. #6 Re: DIC's are for babies :)
    Willoughby, Ohio
    when i need all those guages ill do this mod ha
  7. #7 Re: DIC's are for babies :)
    West Side Michigan
    mmm Wanna make me one :P
  8. #8 Re: DIC's are for babies :)
    Joliet, IL
    Quote Originally Posted by nawarkk View Post
    i actually have another dash and supplies 125$ and you can have one its alot of work and big mess.....and will prob cost me 20$ to ship it....lemme know....pm me.
    00 Silvermist GTP
  9. #9 Re: DIC's are for babies :)
    West Side Michigan
    Damn.. not looking to spend that much lol I might give this a try when schools out. Good job on it btw.
  10. #10 Re: DIC's are for babies :)
    Feb 2009
    The only reason i ask is because you really should have glassed it, bondo will crack when flexed a tiny amount.
  11. #11 Re: DIC's are for babies :)
    Joliet, IL
    i thought of this as well and tested my mixes, when i used slightly less hardener it dried more hard/rubbery...used that mix and i tested that already and flexed it b4 paint with no issues and on top of that the truck bed coating dries to a plastic hardness
    00 Silvermist GTP
  12. #12 Re: DIC's are for babies :)
    Ohio
    looks nice!
    00 GTP demodded and forsale
  13. #13 Re: DIC's are for babies :)
    Willoughby, Ohio
    guess he will find that out the hard way! maybe he should keep that extra dash he has just in case
  14. #14 Re: DIC's are for babies :)
    Joliet, IL
    i was worried about this too until i flexed it around alot.
    00 Silvermist GTP
  15. #15 Re: DIC's are for babies :)
    Willoughby, Ohio
    i see well then you're set! good luck with the install i cant wait for pics
  16. #16 Re: DIC's are for babies :)
    Joliet, IL
    will try to get them up later tonight if not tomm for sure.
    00 Silvermist GTP
  17. #17 Re: DIC's are for babies :)
    Willoughby, Ohio
    sounds good!
  18. #18 Re: DIC's are for babies :)
    Feb 2009
    Alright cool. Was just worried because i know that when you try to pull that dash piece off it flexes most of the time.
  19. #19 Re: DIC's are for babies :)
    London Ont, Canada
    Looks really good.. i like how the 3rd one sticks out a bit giving it some shape
    hell if you need a 4th gauge move the fog switch someplace else and throw one in there!
  20. #20 Re: DIC's are for babies :)
    Joliet, IL
    i wanted them all to face me and clearance wise this was how it fit best i had to file some plastic under the dash a bit for the squeeze nothing major and yes it did give it nice shape esp since i wrapped it in bondo and contoured it
    00 Silvermist GTP
