Thread: Removing ash tray/rearranging cigarette lighter?
Results 1 to 7 of 7
  1. #1 Removing ash tray/rearranging cigarette lighter?
    Donating Users Deezul_AwT's Avatar
    Feb 2008
    Cumming GA
    I don't smoke and won't allow it in my car, so I don't need the ashtray. Since the cigarette lighter is attached to the pull out tray with the ashtray, is it easy to take the lighter out of the tray and take out the ashtray out? I want to retain the lighter for power, in addition to the one on the passenger side. I'm thinking of mounting it farther back, as I don't need the lighter feature, just the power feature. Is this doable?
    2016 Ford Fusion Energi Titanium - Still trying to figure out what I can do
    2006 Mercury Mariner Hybrid - K&N Drop in filter. Not much else you can do...
    TOTALED 9/2016 - 2004 Impala SS
    SOLD 3/2013 - 2000 Grand Prix GT
  2. #2 Re: Removing ash tray/rearranging cigarette lighter?
    Saraland Alabama
    anything is possible with enough tools, I think it's just a couple of bolts
  3. #3 Re: Removing ash tray/rearranging cigarette lighter?
    GT Level Member drunknmunky's Avatar
    McDonough/Warner Robins, GA
    i thought about doing this too, but instead i took out the ashtray cup itself, it just pops out, and use the slid tray with lighter outlet for other purposes... i put a flat peice of ABS in the now open hole from the ashtray cup, and used it to hid switches in there... (for strobes, and soon for the angeleye rings if i hook them up in my projectors....)
  4. #4 Re: Removing ash tray/rearranging cigarette lighter?
    Feb 2008
    Cumming GA
    I have a 3 way splitter that I want to try mount where the tray is now, so that's why I need to remove it. I think it will just look cleaner to have it there as well as allow me to still use the storage in front of the console. I also have a satellite radio power cable that is short, so I can't just mount the splitter on the passenger side where the additional outlet is. I'm probably going to have to pull off the dash soon anyway to try to replace the LCD light on the factory radio that is out, but that's another thread.
  5. #5 Re: Removing ash tray/rearranging cigarette lighter?
    Feb 2008
    Cumming GA
    Just an update. You can remove the tray, it just requires a bit of work. I had to put the car in gear to give me room, and pulling and shifting the tray side to side worked it out. Just be careful not to pull too hard or you might break the cables attached to the lighter. Once the tray was out, I disconnected the power to the cigarette lighter. More spinning and pushing and pulling got the cigarette lighter off the tray. Now I just need to attach my splitter to the metal piece directly under the A/C-heater controls, and I'll have my mount. And as soon as I get my tape player, accessory cable, and new LED, I can put my dash back together!
  6. #6 Re: Removing ash tray/rearranging cigarette lighter?
    Saraland Alabama
    can you see the area it mounts (as in the bracketry)?
  7. #7 Re: Removing ash tray/rearranging cigarette lighter?
    Feb 2008
    Cumming GA
    Quote Originally Posted by archemedes View Post
    Kind of. But I didn't unscrew anything permanently, as I took out four screws and it didn't move. There were two directly under the air controls, and two farther back in the small console storage. I saw a fifth screw to the right of the console storage, but I couldn't see how it would affect the tray either. I wanted to leave the metal plate to use it for mounting purposes, so it is possible that taking that plate out would also remove the tray.
  1. Removing alternator housing
    By David99GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-06-2010, 06:14 PM
  2. help removing altenator case
    By chitownchevy in forum Off Topic Discussion
    Last Post: 09-16-2008, 06:47 AM
  3. lighter coil pack bracket?
    By s1795so2 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-10-2008, 08:29 PM
