Thread: SD Ram Air hood NOT LOCKING
Page 2 of 2 FirstFirst 12
Results 21 to 36 of 36
  1. #21 Re: SD Ram Air hood NOT LOCKING
    Largo, Florida, United States
    Quote Originally Posted by AdamBall View Post
    Why do you have to start criticizing right away? Like you never had a problem while working on a car? He is having a problem with his hood and instead of possibly f*cking something up he decided to ask for some advice before continuing.
    Now to help out here is a picture of the 3 bolts you need to loosen to adjust your hood latch
    Thank you very much. I was thinking people where talking about the Bolts Holding the Latch on the Hood
    This is very helpful.
  2. #22 Re: SD Ram Air hood NOT LOCKING
    GT Level Member AdamBall's Avatar
    Wausau, WI
    No problem Let me know how it goes.
  3. #23 Re: SD Ram Air hood NOT LOCKING
    Donating Users Nickell's Avatar
    Dec 2008
    Cedar Rapids, IA
    I had the same problem with the hood i just got, you need to limp it to a body shop.
    The hoods are being made with to big of a front lip now, take it to a body shop they literally have to shave the front of the hood down so it will close. Adjusting the hood latch doesnt help at all.
    It cost me $90 to get the hood shaved down so it would close, now it is perfect.
  4. #24 Re: SD Ram Air hood NOT LOCKING
    i hope thats not my issue.
  5. #25 Re: SD Ram Air hood NOT LOCKING
    Yeah didnt help much at all.
  6. #26 Re: SD Ram Air hood NOT LOCKING
    Dec 2008
    Cedar Rapids, IA
    im telling you, you have the same problem as me.
    push the hood down in the front with your hang, it will hit the bumper cover before it latches correct? that is why it needs shaved down..
  7. #27 Re: SD Ram Air hood NOT LOCKING
    GT Level Member shawn3091's Avatar
    Jan 2009
    State College PA
    lmao is that a ascd hood? if it is all i can say is wow, i had the same problem, i could not get enough adjustment to bring that latch up high enough even after using die grinder to open them up even more, i ended up measuring and the loop on the hood was 1/4 shorter than the original hoods loop was, so i contacted ascd about getting another loop and they were rude to me about it and i ended up getting a friend to make me one out of stainless rod and we tapped the threads on the end so it could be bolted up to the hood like the original is. if you reach in the hole there will be 2 8mm iirc nuts that are holding the loop to the hood, they are a pain to get at but it can be done
  8. #28 Re: SD Ram Air hood NOT LOCKING
    Dec 2008
    Cedar Rapids, IA
    yeah mine was asdc and the hood its self had to be shaved in the nose section.
    though i will say it fits perfect now and looks amazing.
  9. #29 Re: SD Ram Air hood NOT LOCKING
    i got mine from PFYC
  10. #30 Re: SD Ram Air hood NOT LOCKING
    Jan 1970
    Maquoketa, Iowa
    There should be a 4th bolt to loosen that extends to the bottom of the radiator support along with those 3 pictured. Loosen all of these, move the bracket up as high as you can get it and tighten them. If the hood still does not close then take it to a body shop to have a second look before you start shaving part of the hood off.
  11. #31 Re: SD Ram Air hood NOT LOCKING
    GTX Level Member imdaman3's Avatar
    Feb 2010
    ohio
    ^^ agree
  12. #32 Re: SD Ram Air hood NOT LOCKING
    never messed w/ a gp hood. but on my cav. i actually just took out the bump stops. and that was my problem.
  13. #33 Re: SD Ram Air hood NOT LOCKING
    Dec 2008
    Cedar Rapids, IA
    im telling you, the hood has to be shaved. they come out of the molds with to big of a front lip now.
  14. #34 Re: SD Ram Air hood NOT LOCKING
    Jul 2008
    sumter,south carolina
    ill buy it from u for 100 bucks since u chipped it if u give up on it.
    02 GTP with mods 05 GP for DD
  15. #35 Re: SD Ram Air hood NOT LOCKING
    Dec 2008
    Cedar Rapids, IA
    gtp who ru talking to?
  16. #36 Re: SD Ram Air hood NOT LOCKING
    Banned - Busted For Scamming
    Feb 2009
    spartangl.
  1. HELP. security system locking me out?
    By jd67fire in forum Audio, Security & Visual Electronics
    Last Post: 01-02-2010, 12:15 AM
  2. brakes locking up on me
    By Martin 04 in forum Brakes/Suspension/Chassis
    Last Post: 11-13-2008, 09:19 AM
  3. PE Not locking in at Zero?
    By Sabrewings in forum PCM Tuning
    Last Post: 08-12-2008, 06:54 PM
  4. Locking Lug nuts For GXP
    By GXPimpin in forum Tires & Wheels
    Last Post: 07-10-2008, 12:45 AM
  5. Door not locking
    By J_Man55 in forum General Tech Discussion
    Last Post: 06-30-2008, 01:09 PM
