Thread: Cool Trick with HIDs..
Results 1 to 7 of 7
  1. #1 Cool Trick with HIDs..
    SE Level Member abuckley1290's Avatar
    Jul 2008
    I put my HID's in today and noticed a trick. I am not sure if anyone has noticed this but I figured id share it. In my 2002, if I leave the high beams on the headlights turn off. This also means that the security flash has no headlight, just corners. So I did not have to do a rewire and i still get just the corner lights flashing with the lock/ unlock
    40th Anniversary GP
  2. #2 Re: Cool Trick with HIDs..
    Norristown, PA
    Let me get this straight, you leave the highbeams on when you get out and lock it and they don't flash? I'm lost.
  3. #3 Re: Cool Trick with HIDs..
    Jul 2008
    Quote Originally Posted by rocafella2032 View Post
    yes
    40th Anniversary GP
  4. #4 Re: Cool Trick with HIDs..
    GTX Level Member Warhellride's Avatar
    Norfolk, VA; originally from NH
    The security flash flashes whatever lights are on. So, if you leave your high beams on, it'll flash the high beams. I assume the OP has low beam only HID's, and gets no flash since he doesn't have high beams. Similarly, if you leave the foglights on it'll flash the foglights with the headlights.
    2004 Mercedes-Benz CL55 AMG
    2002 Redfire Metallic Grand Prix GT Coupe (sold after 141,754 miles)
  5. #5 Re: Cool Trick with HIDs..
    Norristown, PA
    how do your lights stay on with your key not in the ignition? do you leave your headlight switch on?
  6. #6 Re: Cool Trick with HIDs..
    Sorry. The security flash flashes whatever lights would be on if the lights were on. You don't leave the headlights on, just leave the switch in the high beam position. I hope this answered your question.
  7. #7 Re: Cool Trick with HIDs..
    Jul 2008
    sorry if i made it confusing. Basically, If you have low beam only HIDs, leave the high beams on and the security will flash to parking lights only....no wire cutting neccesary
    40th Anniversary GP
  1. I'm in Detroit, TRICK
    By MizzBecca in forum Midwest
    Last Post: 04-07-2010, 08:51 AM
  2. 04+ mph/kmph Trick??
    By offroadfury6 in forum General Tech Discussion
    Last Post: 08-08-2009, 06:20 PM
  3. Cheap cold air trick
    By SDGTP99 in forum How To Write-Ups/Tech Tips
    Last Post: 06-15-2009, 01:51 PM
  4. cone filter on the tb trick
    By pontiacGTP123 in forum General Tech Discussion
    Last Post: 05-14-2009, 11:33 PM
  5. July 17 - Tinley Park, IL - Def Leppard, Poison, Cheap Trick
    By FastKatt in forum Shows and Events
    Last Post: 04-08-2009, 12:47 PM
