Thread: rear door light??
Results 1 to 4 of 4
  1. #1 rear door light??
    Donating Users kind153's Avatar
    Pittsburg, KS
    I don't know what it's called,, so I'm attaching pictures.
    This. front driver's side door.
    Rear driver's side.
    Is it normal to NOT have a light bulb in it? 194?
    I bought bulbs thinking they were out without me knowing it, but when I opened it, no wire, no socket, nothing.
    Anyone know how to run a wire with minimal splicing?
    Thanks,
  2. #2 Re: rear door light??
    GTX Level Member Warhellride's Avatar
    Norfolk, VA; originally from NH
    It's normal. The rears don't have them, and they took them out of the fronts in the newer models (starting in 2000 IIRC). The red lens has a spot for the bulb, but no socket or wiring. If you want the clear lens, you can get them from Morad. You'll have to buy a 194 pigtail and splice it into your wiring.
    Here's a link to a 194 pigtail. It was a quick search, so I don't know if it's the cheapest you'll find.
    Product Details | 0.27A 12V,Twist-In Socket Pigtail W/#194 Bulb F/Marker Lamps | Fastenal
    2004 Mercedes-Benz CL55 AMG
    2002 Redfire Metallic Grand Prix GT Coupe (sold after 141,754 miles)
  3. #3 Re: rear door light??
    Pittsburg, KS
    Quote Originally Posted by Warhellride View Post
    I'm willing to do wiring.. Do you know what wire do I have to tap into? I don't think any wire that comes into the the rear doors (window switches) is related to door status.
  4. #4 Re: rear door light??
    Probably would be easiest to tap it into the dome lights, although it would take a lot of wire.
    Another way would be to wire it into the door switch (senses when the door is open) so that the lights come on only when the door is open. You'd need to find someone with more electronics knowledge than me to make it work, though.
  1. rear interior door removal
    By jasonball in forum 04+ Specifics
    Last Post: 07-25-2009, 01:29 PM
  2. gtp door badge in rear? or leave it debadged?
    By 2000GTP in forum Visual/Body Modifications
    Last Post: 02-19-2009, 12:18 PM
  3. Rear Bumper Removal and Fog Light replaced
    By cboth686 in forum General Tech Discussion
    Last Post: 12-27-2008, 07:09 PM
  4. Rear door will not shut *Solved*
    By Fish in forum Visual/Body Modifications
    Last Post: 12-25-2007, 02:53 AM
