Thread: Boostjunki3: Help
Results 1 to 17 of 17
  1. #1 Boostjunki3: Help
    Donating Users bbptech's Avatar
    Box Elder, South Dakota
    Im wondering what kind of weather stripping u used on your halo projections? And other things u did to solve the bounce.
    Thanks,
    bbptech
    ZZP 10.4mm's, ZZP S2 IC, 3.4, 3.0, Ported Gen V, ZZP Headers, ZZP CNC Heads, ZZP 78mm TB, ZZP Aluminum Valve Covers, Meziere Electric WP, ZZP Fuel Pump, ZZP Fuel Logs, 65 Mototrons, 3.29's, 2500 Stall. Tuned by GLANZERGTX and Kyle. E85 Converted, 21* Timing
  2. #2 Re: Boostjunki3: Help
    Iowa
    There is a write up over on clubgp on a anti bounce mod someone did, it seems to work pretty for for everyone tht has done it.
  3. #3 Re: Boostjunki3: Help
    ya ive done that mod and it still bounces some. seen boostjunki3 did some different weather stripping on the housing and it fixed his prob. the bounce just gets annoying since i have HID's
  4. #4 Re: Boostjunki3: Help
    Norristown, PA
    you get weather stripping at pretty much any auto store, get the thinnest possible and put it under the projector
  5. #5 Re: Boostjunki3: Help
    Alright thank u. Any other things u guys did?
  6. #6 Re: Boostjunki3: Help
    Norristown, PA
    i havent done the weather stripping, mine dont bounce...but the weather strippng should help alot
  7. #7 Re: Boostjunki3: Help
    im hopin so. Ill keep u posted. thanks rocafella.
  8. #8 Re: Boostjunki3: Help
    Norristown, PA
    no problem, just dont ask me how to install hids!!
    i fail everytime
  9. #9 Re: Boostjunki3: Help
    Joliet, IL
    just get automotive weather stripping from home depot and rip the original bull shyt off the corners too and wrap the corner and whole underneath of the light with the thicker stuff....another thing i did to get rid of the gap on the inside in this pic below is i grinded the mounting bolt holes for the head light back and in so the light is firm against the frame and further in to get rid of the ugly gap on the inside edge of these lights (thats no pictured here ill get some today or will try)
    00 Silvermist GTP
    13.2 @ 104. No Cam No IC.
  10. #10 Re: Boostjunki3: Help
    Joliet, IL
    heres what i was talking about see how i enlarged the hole up and in....i just drilled another hole really close and grinded out the the piece between the holes then painted it so it wouldnt rust.
    00 Silvermist GTP
  11. #11 Re: Boostjunki3: Help
    chicago
    hey i was wondering if you put a washers in the original holes would that help?
  12. #12 Re: Boostjunki3: Help
    Joliet, IL
    it will lower the headlight minimally but not gonna do much ....
    00 Silvermist GTP
  13. #13 Re: Boostjunki3: Help
    Joliet, IL
    took alot of trial and error to get these bounce free
    00 Silvermist GTP
  14. #14 Re: Boostjunki3: Help
    Hey BoostJunki: I cant find the weather stripping. Everywhere i look, none of it is the right stuff.
  15. #15 Re: Boostjunki3: Help
    its AWDsome JarenSTi's Avatar
    Hawaii
    should i see if mine bounce first before i do this?
    and where did u look bbptech?
    2002 WS.6- exhaust, 42k miles
    2005 Subaru WRX
    2002 GT - sold
  16. #16 Re: Boostjunki3: Help
    SE Level Member Slueth66's Avatar
    Nov 2008
    Iowa
    Is this the the type of weather stripping your talking about?
    Amazon.com: Weatherstripping Tape (Various Sizes) - x 8': Automotive
  17. #17 Re: Boostjunki3: Help
    Hawaii
    i got the stuff from walmart, its 3/4" wide and 1/2" thick,
    will it work?
    2005 Subaru WRX
    2002 GT - sold
