Thread: My 1998 GTP
Results 1 to 20 of 23
  1. #1 My 1998 GTP
    SE Level Member SilverGT's Avatar
    Feb 2009
    Saskatchewan Canada
    Hey guys/girls. I have owned a Silver GT GP for the past year or so. I finally figured it was time to sell it and upgrade. I picked up a 1998 GTP earlier this month. White with leather, sun roof and HUD. Now Im working on getting some mods done.
    So far I have done:
    Brake fluid flush
    Transmission oil/filter change with Synthetic
    Fuel filter
    LIM Gaskets
    NGK copper spark plugs
    MSD wires
    TDC Intake
    ZZP HUD gauge pod
    Aeroforce Gauge
    AEM Wideband
    Alpine deck, kenwood 800watt amp and a crappy Sony sub
    XXR 006 Wheels 18x9.5 with Nexen N3000 255/35/18 all around. No rubbing issues
    Painted calipers
    Debagged the trunk
    What needs to go on:
    6k HIDs with my new healight housings
    HID Relay harness
    Tuned PCM
    180 t-stat
    ZZP Downpipe
    Alt booster
    Alt re-wire
    Shorter dog bones
    What I need to order:
    PLOG
    Cross over pipe
    Modular pulley system with 3.4" pulley
    But anyways, here she is:
  2. #2 Re: My 1998 GTP
    Apr 2009
    Wausau, Wisconsin
    Nice car!
  3. #3 Re: My 1998 GTP
    SE Level Member bigboibbp's Avatar
    Chicago
    very nice man!
  4. #4 Re: My 1998 GTP
    GT Level Member EmEaston24's Avatar
    Pittsburgh
    nice. diggin the wheels and gauge pod
  5. #5 Re: My 1998 GTP
    Iowa
    how hard was it to install your gauges, i want some.
    Nice looking car too man..
  6. #6 Re: My 1998 GTP
    Feb 2009
    Saskatchewan Canada
    Thanks for the comments guys. The gauges were pretty easy to as long as you have a general idea what your doing.
  7. #7 Re: My 1998 GTP
    Banned - Busted For Scamming
    Feb 2009
    turbo.
  8. #8 Re: My 1998 GTP
    Donating Users JDCMoney's Avatar
    Middleboro, Ma
    White on Black = SEX!
    Looks good!
    1998 Blue Raspberry Slushy Metallic GTP: The Daily currently has 185k+
    1989 Sierra:
    Weekend Warrior 1997 Regal GS: Stock For Sale 2000 GTP: Parts Car
  9. #9 Re: My 1998 GTP
    GTX Level Member nicksilvergt99's Avatar
    Reading, PA
    lower it for sure!
    "This shocker crap is for high school kids, it's all about the double gauntlets, that's right, 2 fists forearm deep, someone make me a sticker. double gauntlets > shocker"
  10. #10 Re: My 1998 GTP
    Jersey
    not sure how i feel about those rims but, that thing is clean.
    16' wrx sti- stock
  11. #11 Re: My 1998 GTP
    Aug 2008
    KCMO
    car looks good but you need a little bit more tire on those wheels and you need to lower that betch
  12. #12 Re: My 1998 GTP
    Feb 2009
    Saskatchewan Canada
    I plan on lowering it once winter passes. Im going to probably run KYB struts and Eibach springs.
    Im limited how wide of tire I can run on those rims since they are 18 x 9.5" all the way around with a +35 offset. Anyhting wider than 255 will rub without a fender roll. I like how they look stretched but thats my opinion.
    I was considering turbo or a twincharge setup but I think Ill be going for some 1.8 roller rockers, intercooler and 3.2 pulley in the spring. I would be quite happy running 12's until I get the car I really want (this is my daily driver)
    This is what the rims look like off the car. I love them and they do get lots of compliments but to each his own. But either way they are under $200 a rim and you can get a 3.5" lip
  13. #13 Re: My 1998 GTP
    Aug 2008
    KCMO
    im saying more side wall like a 45 instead of a 35
  14. #14 Re: My 1998 GTP
    Feb 2009
    Saskatchewan Canada
    Oh thought you ment wider haha.
    It will look much better once lowered with those tires.
  15. #15 Re: My 1998 GTP
    GT Level Member Perry125's Avatar
    maryland
    Since you asked...
    Id say get some clear corners becuase the amber kind of sticks out to me.
    And when you buy new tires get some more sidewall.
  16. #16 Re: My 1998 GTP
    GT Level Member 01gtspecial's Avatar
    Apr 2009
    Georgia
    drop the *****!
    nice car
    01 GT special ed.: SD hood, GMPP kit, poly sway bushings, Eibachs/Gabriel Ultras, Eagle GTs, ZZP anti-pogo, ZZP short dogbones, ZZP poly trans, ZZP PCM, ZZP HV TB, ZZP HV3, P&P LIM, 4" FWI, 3" DP, custom exhaust, pwdr-coated Trans Am brakes, NGK iridiums, Mobil1 Syn fluids, stage 2 voltage booster, BIG 3, real loud stereo...
  17. #17 Re: My 1998 GTP
    Feb 2009
    Saskatchewan Canada
    Thanks guys.
    I need to do exhaust tips also
  18. #18 Re: My 1998 GTP
    Joliet, IL
    lower and run a 45 profile tire....looks too low riderish with those rubberband tires....other wise hott!
    00 Silvermist GTP
    13.2 @ 104. No Cam No IC.
  19. #19 Re: My 1998 GTP
    Feb 2009
    Saskatchewan Canada
    I dont have the money right now to switch tires. They werent originally ment for this car though. I put the rims on after I parted it out the other car.
  20. #20 Re: My 1998 GTP
    Joliet, IL
    makes we wanna get a white 4 door and put all my parts on it
    00 Silvermist GTP
  1. My 1998 GTP project...
    By twiggsta in forum Visual/Body Modifications
    Last Post: 03-12-2011, 12:08 AM
  2. new 1998 GT no start !
    By pughman in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-30-2009, 01:21 PM
  3. 1998 ram air hood?
    By jprovinsal in forum Visual/Body Modifications
    Last Post: 02-07-2009, 01:05 AM
